20 Most Recent
American Standard Traditional Champion4 2034.004.165 Silver One-Piece Elong Questions & Answers
I have an american standard toilet which is flushi...
If you have that thing off, take it outside and put it up on saw horses, fill the back with water and flush it, see if it is still slow. Then get your kid to reach up there and get his toys out if it doesn't flush. You might have to do it a couple times. Then if it does flush, you know it is clogged down the line or something is blocking the vent. Got squirrels? Check it out.
5/25/2010 11:09:42 AM •
American...
Answered
on May 25, 2010
Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
8/1/2009 7:09:57 AM •
American...
Answered
on Aug 01, 2009
Poor flush, need to repeat.
probably is. You can fix it yourself very easily.
Go buy a FluidMaster flush vale (Home Depot for about $20.00) follow directions in the box and you should have it fixed in about 30 minutes or less
Save you a bunch on labor by the plumber.
Kurt
4/8/2009 6:00:14 PM •
American...
Answered
on Apr 08, 2009
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
