20 Most Recent
Daewoo KOR-63D5 Convection/Microwave Oven Questions & Answers
How to cook hotdogs?
Use fresh rolls.
Boil the hot dog sausages on your stove.
Peel and prepare your onions, frying them lightly on your stove.
**** a roll lonways and place the boiled sausage in the cutting and add fried onions and tomato sauce to taste.
Lovelly!
I have a daewoo countertop microwave/convection
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
The turntable comes off it's track and sparks. the
Sounds like you haven’t correctly centered the ring assembly under your glass platter. Remove the glass platter, now place the plastic ring with tiny wheels in the center and move it around by hand. You will be able to tell instantly if it’s centered correctly. Now place the platter on the center hub gear.
To replace the coating on the microwave glass visit these web sites. www.partselect.com or www.applianceaid.com and enter your model number then scroll down to your part. Click to enlarge and you will be able to view the entire diagram for exact assembly. If you found any of these suggestions helpful, please rate my solution. D. Lange
Daewoo KOR-7LREM Retro micro
Sporadic:sometimes heats up the food & most of the time doesn't heat like it should-have to add time to the recommended time but getting increasingly unreliable.
Does it have a turn table that spins your food container? If so, does it turn? If not, you are getting a solid directed beam of microwaves focused on one part of your food leaving the rest of it ignored. If it doesn't have a turn table, it will have a wave spreader inside which is nothing more than an aluminum fan that is sometimes driven by a small motor and rubber belt. You won't see this as it is inside the chamber that contains the magnetron that generates the microwaves. These belts can break allowing a solid, focused microwave beam to shine on your food rather than be distributed around the oven, again, leaving the rest unwarmed. If this is the case, using the oven can damage it over time. If you don't know what you are doing, DO NOT try to repair it yourself!!! If you don't get the outer casing back together properly, you can expose yourself and / or your family to dangerous amounts of microwave radiation. You should take it to a qualified service center for repair but I would venture a guess that it is already damaged because of your statement "but getting increasingly unreliable". Even if it isn't damaged, it will probably cost you more in labor to fix it than it would cost to replace it. Good luck.
