20 Most Recent
American Standard Hampton Two-Handle Bath/Shower Faucet ... Questions & Answers
I am trying to remove
The screws ae under the center cap. unlike todays faucets this cap is screwed in. You will see a little edge on the cap so you can take your channel locks and turn it counter clock wise. Under that is the bress screws.
You might need a handel puller if they have not been appart for so many years. The puller will also protect you from breaking the stem and the handle.
Hope this helped you out, we all know how little things kick our butts.
Thanks again
Tom
9/9/2011 6:57:27 PM •
American...
Answered
on Sep 09, 2011
Cold water handle on my American Standard cold
There is an adapter from the faucet stem to the handle. A small gray plastic faucet part that
frequently causes problems for many owners. You will need to call
American Standard and ask for a new handle stem connector. The faucet came with a limited lifetime warranty and the part should be free. While you are getting one, you might as well get another for the other handle. American
Standard's phone number is
1-800-442-1902.
9/6/2010 10:44:22 AM •
American...
Answered
on Sep 06, 2010
I have Hampton 2 handle
Hello. I do not blame you one bit for your displeasure with this slipshod work. I would not accept it either. If you have already paid the bill by check call your bank and stop payment. If you put the cost on a credit card file a complaint with them. Call the plumbing company and ask to speak with the owner. Write down what you plan to say. Be polite and somewhat friendly but also firm. No matter what he says, do not loose your temper. Simply state that the workmanship is unacceptable; and, that you want him to come out and see for himself as he probably won't believe it. IF he balks tell him you will file a written complaint with the Better Business Bureau and the Attorney General of your state.....and follow-up unless of course you get the satisfaction you deserve. Good luck with it. Remember............polite, but firm. AND always have paper and pencil by your phone so you can begin by writing down the full name of the person you speak with. IF it is not the owner, and you aren't given the answers you know you deserve ask what the name of his supervisor is, wirite that down and then ask to speak to that supervisor. You will win this, I assure you! Regards, Joe
1/14/2010 9:10:36 PM •
American...
Answered
on Jan 14, 2010
Faucet sounds like a fog horn
It sounds like the faucet washer has come loose. Pull out the valve and replace the washer or just tighten the screw.
Please rate if this helps-
3/29/2009 2:52:08 AM •
American...
Answered
on Mar 29, 2009
Cold water shower handle
It sounds as though the handle might be turning on the stem or most likely the washer is worn out. You have to turn the water off at the faucet or to the property. Remove the handle and then procede to remove the stem. Sometimes you have to have a special hex wrench to remove the stem. The washer will be at the end of the stem. While you have the stem pulled, I would remove and replace the seat as well which requires a seat wrench to remove it. That's pretty much it. It's not real hard if you have the proper tools to do it. But sometimes it can be a real pain. Good luck!
3/24/2009 10:50:32 PM •
American...
Answered
on Mar 24, 2009
Clogged sinks and toilets
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
4/6/2022 3:13:10 PM •
American...
Answered
on Apr 06, 2022
Speed connect drain will not go down completely
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
12/10/2018 11:24:22 PM •
American...
Answered
on Dec 10, 2018
American standard 2k-2h still leaks after replaceing sem and nut
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
4/13/2018 10:58:01 PM •
American...
Answered
on Apr 13, 2018
How do i remove bathroom sink drain plug?
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
1/12/2018 10:02:19 PM •
American...
Answered
on Jan 12, 2018
How to replace the trap for kitchen sink..there is
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
9/13/2017 12:13:07 AM •
American...
Answered
on Sep 13, 2017
