20 Most Recent Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Questions & Answers
7answers
Price pfister soap dispenser will not work
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
2/8/2019 7:37:08 PM • Price Pfister... • Answered on Feb 08, 2019
2answers
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
2/25/2018 4:11:00 PM • Price Pfister... • Answered on Feb 25, 2018
Low water pressure coming out of faucet. good press at ang stop.
If you just installed it check to see if it has a water saving feature that in some homes and almost restrict all the water force
2/18/2018 8:02:09 AM • Price Pfister... • Answered on Feb 18, 2018
2answers
Faucet will not swivel
if your faucet is new....the spout was put together wrong and it needs to be removed and re-attached correctly...(friction washer/ring in wrong position).....if not new....spray some penetrating oil on the connection that is supposed to swivel....make sure the surface is dry and try to avoid overspray. let it sit for 15 min...then spray it again...and again let it sit ....after sitting for a few minutes.....gently try to move the spout side to side...if no change...repeat the first processs...and continue to repeat until it becomes moveable....once moveable....detach the spout.....dry out and remove any foreign matter from the connection side on the faucet...then apply a small amount of faucet grease to the connection threads and the inside barrel....a thin even coat ...excess grease will clog your aerator...don't use too much....now repeat the cleaning and lubricating process on the removed spout connector....reassemble.....remove aerator....turn on the water and flush....replace the aerator....turn water on full blast....check for leaks and for swing...it should swivel now ....if not...loosen the connection nut a tad and try again....if still no swing....you are missing a friction ring somewhere in the connection and it needs to be replaced before you will be able to swing the spout.....good luck...
12/4/2017 9:12:02 PM • Price Pfister... • Answered on Dec 04, 2017
Water shoots out of my faucet, now can I plug it?
water is supposed to come out of your faucet...in a controlled fashion....if its at the handle....remove the handle and locate the source....tighten the packing gland or replace a seal. if it sprays all crazy at the spout...try unscrewing the little piece on the tip of the spout (aerator)....flush your faucet by running the water with it off...then flush out the screen on the aerator and re-attach it...hope I was some help....good luck and always know where and how to turn your house water supply off before working on any pressure points on your water supply system.
5/23/2016 4:33:50 PM • Price Pfister... • Answered on May 23, 2016
About a week ago it suddenly dropped water pressure by half, what do you think is causing this problem? We have had the faucet since 2013 with no problems
there may be garbage in the strainer. unscrew the strainer where the water comes out and check the screen inside there. it could have a partial blockage
8/17/2015 5:39:42 PM • Price Pfister... • Answered on Aug 17, 2015
3answers
I can't disconnect the quick connect sprayer hose Price Pfister
HI, parts can be found from amazon (entire assembly too), take a look here: Amazon com price pfister marielle kitchen faucet parts. Wish you best of luck. Cheers
1/6/2015 5:35:26 AM • Price Pfister... • Answered on Jan 06, 2015
My kitchen faucet handle makes a screaming sound and will not turn the cold off
Either you didn't seat the o rings properly or they are the wrong size or the cartridge needs replacing
7/18/2014 6:05:29 PM • Price Pfister... • Answered on Jul 18, 2014
Will loose pipes cause water hammer
LOOSE PIPES ARE WATER HAMMER.
5/30/2014 5:27:03 AM • Price Pfister... • Answered on May 30, 2014
Rattling noise in water pipes
YOUR WATER PIPES ARE NOT FIRMLY MOUNTED,IF A PIPE MOVES IT WILL MAKE NOISE,NO MATTER WHAT FAUCET YOU HAVE.
5/30/2014 5:20:52 AM • Price Pfister... • Answered on May 30, 2014
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
3/6/2014 2:28:13 PM • Price Pfister... • Answered on Mar 06, 2014
The soap dispenser on my price pfister kitchen
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
11/18/2013 6:56:17 PM • Price Pfister... • Answered on Nov 18, 2013
Small gray ring on quick connect hose is partially
I will need a few more details. Can you post a pic of what you are looking at?
11/8/2013 4:30:31 AM • Price Pfister... • Answered on Nov 08, 2013
I have a Price Pfister 34 series kitchen faucet
How did you resolve the problem of removing the spout assembly? We also have a Price Pfister 34 series kitchen faucet and are trying to replace the diverter. Like you, we have removed everything down to the spout assembly, which will not simply lift off. We have tried letting it sit overnight with WD40, thinking it would loosen it up. No such luck. Then tried using white vinegar, thinking maybe there were calcium deposits holding it on. No luck. Please tell us that you were successful and how you got the victory over this stubborn thing!
10/20/2013 4:57:21 PM • Price Pfister... • Answered on Oct 20, 2013
2answers
You need an aerator wrench, Pfister part number 941-031. Several vendors on the web carry this part.
10/3/2013 8:36:45 PM • Price Pfister... • Answered on Oct 03, 2013
2answers
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
5/17/2013 4:06:53 AM • Price Pfister... • Answered on May 17, 2013
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
2/23/2013 2:23:36 AM • Price Pfister... • Answered on Feb 23, 2013
Replaing sprayer
The Price Pfister web site has a video showing you how to disconnect the hose. Basically, you have to push the hose end into the junction block and then grasp the gray plastic fitting, pull the fitting, NOT the hose, away from the junction block. This sounds good in theory, but when upside down with your hands stuck in a small crevase under the sink, it can be a real challenge. Go to the Price Phister web site and watch the video. Good luck.
Rick120977
12/3/2012 3:35:40 PM • Price Pfister... • Answered on Dec 03, 2012
The black plate surrounding spray controls fell off,now what?
Is the plate damaged? If so you should be able to get another at the hardware store. Will it slip over the sprayer? If not you will need to turn the water off at the cut off and unscrew the sprayer hose the pull hose through the sink hole and put the plate over the hole then the hose goes back through the hole and screw it back on under sink. It should be good to go.
11/15/2012 6:04:44 PM • Price Pfister... • Answered on Nov 15, 2012
I need the size for o-ring that fits the diverter to sprayer connection on a price pfister kitchen faucet
Hi. Did you know you can find and order parts on the Pfister website? If you prefer you can email us and our customer service team will reply. Please provide: * The model number of the product. If you do not know this, please follow these directions: http://www.pfisterfaucets.com/do_it_yourself/how_to.aspx * A method to contact you (phone prefered.) Please send this information to us at [email protected]. We apologize for your inconvenience and look forward to resolving this matter as soon as possible. Sincerely, The Pfister Team Pfister is a part of the Stanley Black & Decker Hardware and Home Improvement (BDHHI) Group.
4/4/2012 3:25:09 PM • Price Pfister... • Answered on Apr 04, 2012
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
202 questions posted
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Price Pfister Plumbing
Most Popular Question
price pfister soap dispenser will not
  • Plumbing
