20 Most Recent
Price Pfister Genesis Luxury Kitchen Faucet with Pull-Out Spray .... Questions & Answers
Faucet leaks from the body
There is no way to fix that and it is a common problem...
You will have to replace the whole faucet...
heatman101
The on-off mechanism (handle) is
If the faucet is turning it's self off that means that the cartridge is wore out. To fix the problem you will need to replace the cartridge.
Good luck
Handle keeps wont stay up, keeps turning off.
Yes you can repair this. Sounds like the valve springs and the rubber valve seats may be worn. There are repair kits available at Lowe's, Home Depot, Wal-Mart, ect. for these faucets. And they usually come with the "tool" you need to remove the faucet handle and the cap and seal nut. After that, it's pretty straightforward, and easy. Two springs, two seats, and an O ring or two, and your'e done. Just make sure to shut off the supply lines to the sink before you start and open the faucet handle to remove any pressure left after you cut the water off. Tighten the cap or seal nut securely after the new springs and seats are in, and you should be good to go.
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
MY PRICE PFISTER 533-50 HAS
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy.
I have a slow drip on my bathroom faucet. how do i
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
What causes noise when water turns on
are you speaking of water hammer ? as typically this occurs when shutting off water , faucets that make noise like a whistle when on could be a part clogged aerator in the end of it , this happens over time and debris is aloud to collect in end of faucet
