20 Most Recent
Philips 52 In. LCD HDTV Questions & Answers
PHILIPS 52" HDTV BLINKING BLUE POWER LIGHT
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Connecting Ps3 with philips tv
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
Cant get the ps3 to
If you are connecting with hdmi, make sure your connections are proper and you are on the right hdmi source on your TV
Hi i have a problem
Could you further clarify the problem with your tv please? Your display is cf? So your remote control does not work. Do you have control of your tv via its owns buttons? Do you have a picture and have sound?
When I connect my Laptop to a Philips lcd tv via
Hey FixYa
Thank you for your answer.
My problem is that my graphic board in my HP Pavilion Laptop dos not support sound from the HDMI output, only video. That was the reason
why i could not hear anything from my Philips lcd TV.
I wish you all a happy New Year.
Greetings from sgkbcl
Broken Screen
screens cost about 1000 and up - usually not worth replacing
