20 Most Recent
Philips 52PFL3603D/27 52 in. LCD HDTV Questions & Answers
Tv wont turn on
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.
3/27/2012 3:45:09 PM •
Philips...
Answered
on Mar 27, 2012
When i turn on the tv, the PHILIPS image is on
This problems is the causes of the T-CON decoders board is dying.This T-CON decoders board sit at the bottom right in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
12/16/2010 5:45:04 AM •
Philips...
Answered
on Dec 16, 2010
Picture wont come up on TV just the sound, i tryed
Ur tv the LCD inverter board is dead.Replaced this inverter board ur tv will get the picture back.Tries Websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
5/31/2010 12:13:26 PM •
Philips...
Answered
on May 31, 2010
I just purchased a 52 inch phillips tv and the
Just take off the stand altogether if you can lay the TV close enough to a solid vertical support.
My 47'' Philips spent about a year without a stand sitting on a desk and leaning on a wall.
It's heavy enough and as you approach to completely vertical position its main force will be pointing down, not forward.
If you can't lean it on anything solid or if it doesn't sit well while in an entertainment center...not sure what I'd suggest....short of adjustable wall mount stands...
11/7/2009 2:47:05 AM •
Philips...
Answered
on Nov 07, 2009
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
