20 Most Recent Envision L32W761 32 in. LCD TV Questions & Answers
2answers
My TV has lost the red tint so all the reds are yellow what can I do about this?
Look in the menu for factory reset !
5/24/2015 8:58:41 PM • Envision L32W761... • Answered on May 24, 2015
How do I fix the red tint on my 32in Envision TV
You should adjust its white balance. To adjust this, you have to enter its service mode option. The work is really a skilled one; and not can be done by a normal user. It will be best to seek assistance from any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
5/12/2015 6:45:08 AM • Envision L32W761... • Answered on May 12, 2015
2answers
How to buy a base stand where do I go for that?
Universal TV Stand Base Wall Mount for 32 60 Flat Screen Televisions There are a number of options for stands. Do a web search " flat screen base stands" and there will be a number of sites/ products listed. Amazon is one site that has the stands.
2/25/2015 12:07:15 PM • Envision L32W761... • Answered on Feb 25, 2015
How to fix bad switch?
Are you sure you want to if you can get parts for your TV.
1/3/2015 2:44:45 PM • Envision L32W761... • Answered on Jan 03, 2015
Tv wont turn on
Main PCB has the microprocessor on it.
7/24/2014 7:37:55 PM • Envision L32W761... • Answered on Jul 24, 2014
2answers
I have a 32" AOC Envision L32w761 LCD hdtv with no
There are only two things that can cause this problem -inverter and T-con. Since you have already replaced the inverter, it can be nothing other than the T-CON or LCD controller. Replacing the same should resolve the problem. On a side note the inverter/T-Con problem can be isolated easily. The purpose of the inverter is only to light up the backlight of the panel. So when it fails you will still have a faint picture that can be seen if you flash a flashlight on the screen. If you would like me to find you the replacement T-con let me know the part number and I will get you the link to the part.
7/22/2014 12:14:39 AM • Envision L32W761... • Answered on Jul 22, 2014
2answers
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken. If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
7/6/2014 12:58:33 PM • Envision L32W761... • Answered on Jul 06, 2014
My screens broken
You now have a parts set, replacing the screen isn't an option as it will cost more than a new TV set. You can recycle the set at your local electronics recycling facility or place it on Craigslist for parts. You should be able to get $20-$25 for it as is. If I have been of service to you please sign my guestbook page @ http://www.back2lifeelectronics.com/Guestbook.php
7/1/2014 1:53:23 AM • Envision L32W761... • Answered on Jul 01, 2014
Prende y sale unas letras y luego se apaga
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
6/2/2014 5:20:09 PM • Envision L32W761... • Answered on Jun 02, 2014
I've lost the remote control for my AOC Envision L32W761. How can I change the menu and input source options using the front panel controls? I'm able to access the menu screen but can't figure out h
Try navigating the screen using the volume and channel controls. If you still can't get to the left side of the screen then try press the menu button again while on the menu screen to see if it'll navigate you there. Hope this helps :)
4/21/2014 12:18:27 AM • Envision L32W761... • Answered on Apr 21, 2014
0answers
The message no signal is bouncing around on the screen
go to the tv menu. From there it will have options. Go to the one where it says channel scan or signal scan. Run the scan. It will take around 5 to 10 minutes. That should fix it.
3/30/2014 3:40:34 AM • Envision L32W761... • Answered on Mar 30, 2014
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error. If it has been less than a year since you purchased it i would contact them. They will send you to a service center. If it cant be fixed they will replace your tv. It is all covered by them. If it is past a year its honestly not worth fixing it, You can find name brand 32 inch tv's for less than 250 while fixing it would cost around 150.
3/30/2014 3:38:58 AM • Envision L32W761... • Answered on Mar 30, 2014
Mounting on the wall
Yes, you need to purchase a TV wall mount for that size tv. Best-buy, costco, sam's club all sell them
3/7/2014 5:28:54 PM • Envision L32W761... • Answered on Mar 07, 2014
Envision L32W761 32 in. LCD TV Logo
92 questions posted
Top Envision Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Envision Televison & Video
Most Popular Question
l32w961 screen goes black comes back
  • Televison & Video
