20 Most Recent Samsung LN46A650 46 in. LCD HDTV Questions & Answers
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Samsung LN46A650... | Answered on Oct 22, 2019
I do not believe you can connect the TV to the wireless router right out of the box. You need to buy extra equipment in this case, the Samsung Digital Media Adapter. Global Download Center
Samsung LN46A650... | Answered on Sep 24, 2019
Samsung smart TV's can stream from an ipad with the Samsung Smart View app. Samsung Smart View 2 0 on the App Store
Samsung LN46A650... | Answered on Jun 03, 2019
Change the Tcon board and you should be back in business.
Samsung LN46A650... | Answered on Nov 21, 2017
Good used one is fine and less dinero TV Parts Universal TV Stands DLP Chips ShopJimmy
Samsung LN46A650... | Answered on Sep 15, 2017
Could be an open internal fuse or sudden power supply failure
Samsung LN46A650... | Answered on Apr 21, 2017
Tip
Samsung 46" LCD Model LN46A650A1F has dark, slow developing picture from right to left across screen
Picture was dark, slow to develop across the screen from right to left; tapping, pushing or squeezing the upper left corner of the screen would sometimes restore normal brightness and picture. (Two separate problems)There was also a wide vertical band of lines on the right hand side of the screen and sometimes on the left.
The T-Con (Timing and Control board) located at the top middle of the back has (4) flat ribbon cables that can develop bad connections on the contacts. Some, usually only one or two will be the problem.
Gently remove the flat RF aluminum shield at the top frame edge to get at the ribbon cables. Pull down the small brown locking tab to free the cables. Then with slight pressure on the locking tab, gently move the ribbon cable up and down into the connector to restore proper connectivity. You may have to do this several times.
Note: your screen many have the band of lines at the far left, middle or mid left or mid right on the screen. As viewed from the front, the left ribbon cable will cause lines on the left of the screen and the far right ribbon cable will cause lines on the far right of the screen.
The above picture shows the left connector that was the cause of the band of lines on the right side of the screen in my TV.
Some message boards also recommend putting a thin piece of tape across the back of the connector, opposite the connection side to put more pressure on the conducting pins for better contact. It should be thin to avoid putting undo stress on the locking tab. If you break it you'll have to buy another T-Con board.
To fix the intermittent screen and lines on screen located in the upper left of screen, the aluminum frame surrounding the screen will have to be loosened, not removed. All of the small black screw at the top and sides will need to removed and some of the bottom ones to. The frame is flexible enough that complete removal is not necessary. Gently pull the frame away from the top of the screen - only a couple of inches is necessary. At the top left is a small ribbon cable that is the cause of the flashing lines and dark picture. I used a small, round .25"/6.5mm piece of foam and placed it across the edge of the ribbon cable while pushing the frame back into place. See picture where I placed mine to fix. Only use enough length approximately 2" placed over the ribbon cable, not shown, behind the frame as I'm holding in the pix.
These fixes apply to multiple models and screen sizes of flat screens. It should be noted, that if the band of lines on the screen remains stable no matter how much you move or try to clean the contacts on the T-Con ribbon cables then replacement of the T-Con board may be indicated. Good luck.
on Aug 09, 2016 | Samsung LN46A650 46 in. LCD HDTV
So other problem was the power supply. This problem is the TCON board.
Samsung LN46A650... | Answered on Mar 17, 2016
Are you using an antenna, cable box or satellite?
If you are using a cable box or satellite then the problem lies withen the box or sat.
Samsung LN46A650... | Answered on Dec 30, 2015
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Samsung LN46A650... | Answered on Oct 02, 2015
Sounds like fault with its main power supply bard too. Check all the wiring connections from the main board to SMPS board for any loose connection. Improper wiring too can cause this fault, due to AC line interference. Check these well, before replace the SMPS [power supply] board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Samsung LN46A650... | Answered on Jul 25, 2015
Most likely failed capacitors in the power supply. I am currently having the same problem with my 26 month old LN46A750. Samsung has greed to fix this as a "courtesy repair".
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Samsung LN46A650... | Answered on Apr 16, 2015
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Samsung LN46A650... | Answered on Feb 23, 2015
http://electro-medical.blogspot.com/
Samsung LN46A650... | Answered on Jan 18, 2015
Samsung LN46A650 46 in. LCD HDTV Logo
202 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
looking manual tv model no
  • Televison & Video
