20 Most Recent
Sharp Aquos LC-52SE94U 52 in. LCD HDTV Questions & Answers
There are two green lights
The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Why cant i cant recieve a picture or sound.all i get is the power button on front blinks off and on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Does the sharp Aquos LC-52 support HDCP? I have
DISH Network blocks multiple video outputs on all PPV and most premium content to prevent recording, and they will tell you it is a TV issue. Ensure that your receiver only has one video cable coming out, to only one device (ie HDMI to the TV) and try again.
Sharp LC-52SE94U shuts down and restarts automatically
There is a software update for this model via the Sharp website. Included is a link to the compressed folder. Once you uncompressed the folder there are instructions in the folder on how to install the update. It doesn't specifically say this is a fix but as a TV technician personally its the fist thing I would try.
Link to Sharp software update
Tv doesn't power on
Check and replace damaged component/s at its main power regulator board / replace the board as card basis.
Broken screen
If the screen is broken(cracked or shattered) you are done.part wholesale if available is more than set cost new.
Volume does not work with
Tries take the remote aparts,if can,some u can't they're tighten and latches from the inside.Take a rag soak it with some rubbing achahol and clean the PCB board and the inner rubbers plastics knobs on the sheet of rubber plastics that make coonntact to the PCB board.U tries take out the battery awhile and put in a brand new set of battery,remote might work for the volume button again.If not the volume control pad rubber knobe inner plastic pad that press down on the circuit board might be worn out or not making good contact anymore to the PCB circuit board.Or the remote control CPU chip are slowly shorting out the first command it take out was ur remote volume control functions.Try website like Remotes.com to buy another the tv original remote.
