20 Most Recent
Memorex MVDP1102 Portable DVD Player Questions & Answers
Portable dvd wont play movies
I was getting the blue screen and open, then a black screen after loading the disk. If you have the AV switch in the wrong position, it will do the same thing. My kids must have moved it on me.
I have a Memorex 10'2
You will need to contact manufacturer's service center. the http://www.memorex.com/en/Contact-Support/?p=697
Power light doesn't come on
Check the adaptor as this can usually fail, if its not the adaptor try the battery and if it doesnt power up still then its an internal transistor thats shorted.
DVD player - Memorex DVDP 1102 - "NO DISC" message
ok get a cotten swab and put a little alchohol on the tip now gently rub over and around the casing of the lens...gently trying to lift it back up into posistion (your son pushed it down into its casing....You might also try droping it upside down on a soft couch pillow to dislodge the lens (This method has worked for me ) ps its just a hair!
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
