20 Most Recent
Gateway ML6721 Notebook Questions & Answers
Bootmgr is missing on Windows XP System. Gateway
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
When ever I touch my
Look for a small switch near the actual surface and make sure it is not shut off, which disables the trackpad.
My gateway laptop doesnt read
Sounds like a crashed hard drive, swap it out with a new one.
Take your old hard drive with you when you head out to buy a new one to make sure you get the same kind (they're only two kinds for the most part - IDE / PATA has 40 pins and SATA has two L shape connectors.
Hope this info helps!
I installed XP over Vista. Everthing seems to work
You will need to reinstall the drivers for XP as it generally didn't have them all. You can find yours at:
http://tinyurl.com/2wp8n5r
Download to a thumb drive on another computer then install them on the notebook.
My computer gave a smart error stating hard drive
This error means that your HD is malfunctioning (S.M.A.R.T mean Self Monitoring Analysis and Reporting Technology), You need to replace your drive, If it can still be read you must boot from a live cd or live usb an back up from there. When the HD self test throws an error like this there is not much to be done.
I need to reformat my harddrive
you can use the windows installation cd to format the drives, also in windows you can right click on the drive and select format, note that format of C drive is not possible in windows
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
