20 Most Recent
Toshiba Satellite Pro L300D-EZ1002X Notebook Questions & Answers
I have this toshiba satellite
remove the keyboard then remove the wirless card u can see jumper ... short jumper for 15 second... if not keep short jumper and turn on the mechine for 15 second.. hope this way u can remove....thanks
3/30/2011 12:37:09 AM •
Toshiba...
Answered
on Mar 30, 2011
Please help my Tosiba L300 is asking for a BIOS
All you need to do to access the BIOS is to reset it. To reset the BIOS you would need to remove the CMOS battery and place it back, the BIOS password will be back to default and you able to access the BIOS.
NOTE: the CMOS battery is located at the back of your laptop, or it will be much better for you to call a local technician and have him do it for you.
For you to use the recovery disc, once you boot the computer press F12 then select to boot your computer to (CD\DVD drive) make sure that the disc is in the disc tray, then press enter. Your computer will automatically boot into you recovery disc.
Cheers
3/9/2011 5:43:31 PM •
Toshiba...
Answered
on Mar 09, 2011
Problems booting windows vista on toshiba
You may need to re-install the operating system all over again as you had tried to restore your computer using Restore Disc but failed. In these cases, you will have to try to wipe all your data and install OS once again.
3/13/2010 4:47:56 AM •
Toshiba...
Answered
on Mar 13, 2010
Our DVD player on our laptop is not working and
It sounds like your DVD drive has become slightly unseated in it's mount (was the laptop dropped recently?) or else information about it has become corrupted in the operating system.
Will the machine boot to a CD or DVD if it is inserted at boot time and booting from the DVD drive is first in the BIOS settings? If so, the problem is in software, if not, you have hardware problems, likely a bad
DVD drive or the drive has become unseated in it's mount.
If it is a software problem:
Make sure the DVD drive is pushed all the way into the body of the machine, and then go into device manager and right click on the non-functioning DVD drive and select UNINSTALL (or delete). Agree to remove the device completely from the operating system if asked. Now reboot the machine, and it should re-install and initiate the communication with the drive.
If this fails to resolve the problem, you might consider the following more advanced fixes, but beware there are risks involved.
First, go into the system BIOS at boot time and DISABLE the DVD drive in the BIOS and then reboot your machine. In device manager, find the setting for SHOW ALL DEVICES which will show the DVD drive it no longer can see; the icon should be greyed out. UNINSTALL it. Then reboot into the BIOS, and reENABLE the DVD drive in the BIOS and reboot to Windows and see if it is recognised. You can also try going into the drive's properties in device manager and changing/updating the drivers from their default to any other set that is compatible, and then switching back (Windows will change the registry settings each time).
If this fails but the machine will boot to a CD, you might have to consider reinstalling a fresh copy of Windows.
If it is a hardware problem:
Turn the laptop over (unplugged from the power of course) and try to identify the two or three screws that hold the DVD drive in, and carefully unscrew them. With the DVD drive's door open, pull gently and the drive should come clean out of the machine. If it does not come out pretty easily, you have missed a screw. With the DVD drive out, close the door and check the connections on the tail of the unit - is there anything unusual - bent or broken connector? Try reseating the DVD unit firmly in the laptop and rebooting again...
Good luck...
12/8/2009 9:59:39 AM •
Toshiba...
Answered
on Dec 08, 2009
I want to reset bios
You need to open your laptop. Disconnect battery first, unscrew cover and look for the CMOS battery which have the same size of a dime. Remove the battery and return it after 10 seconds. The BIOS shall be reset.
12/7/2009 4:13:39 PM •
Toshiba...
Answered
on Dec 07, 2009
I bought a l300/l300d series toshba laptop a year
Sounds like your operating system is corrupted.
You could try to fix with Malware and Spyware software (Malwarebytes and Spybot), but you probably need to reinstall the operating system (Windows XP ? Vista ?).
There is also a possibility that your memory is bad. Remove all and reinsert one module at a time to test.
Hope this helps.
9/3/2009 9:57:33 PM •
Toshiba...
Answered
on Sep 03, 2009
Lap top wont start up gos to light grey ,dark grey screen
Virus?
Which program is it?
Next time you boot up your PC, boot in safe mode with your internet connection off. Scan your PC. or if you can install programs install "Ashampoo Firewall Free" that way you can monitor your sart-up Items etc...
And also informs you to create a rule Say Windows Live
"WLM is attempting to connect to the web"
<Program path>
[X]
[X]
Make sure it is a program that YOU installed. not your computer.
Best of luck. Tom.
7/13/2009 2:48:05 PM •
Toshiba...
Answered
on Jul 13, 2009
Toshiba L350D Screen Loss
you may plug off remote monitor power on to see carefully is there normal dark picture on your lcd screen,
!) lcd dark but there is pcture on the screen, it means the back lights inverter damage(which in the lcd lid and downside of lcd panel), or lamp damage (in the lcd panel), have to replace new parts
2) no any picture and dark panel, you may check lcd signal cable plugs are right seat in the sockets (which located between the back of lcd panel and motherboard), also check the inverter cable same thing (it merges in LCD cable) . it is better replace a new cable (most cases are cable disconnection somewhere)
is this helpful please feedback when you checked, iwill tell you what you can do next, thanks
5/19/2009 2:53:57 PM •
Toshiba...
Answered
on May 19, 2009
Laptop
lol. I'm in the US, so I'm giving you instructions from an "everybody has ADSL from AT&T" point of view.
try reading this page:
http://www.frequencycast.co.uk/homehub.html
looks like your router config URL is
http://bthomehub.home/
try digging around in there to find/change your password and to see how your wireless is configured. I can't give you more detail, I have never had any experience with HomeHubs... you may wanna read through your homeHub manual (the wireless section or whatever).
ah those British beople always have to do everyhing their own way... lol.
sorry I couldn't be more help. good luck.
1/24/2009 12:44:06 AM •
Toshiba...
Answered
on Jan 24, 2009
Windows vista
Sorry dont understand your question, please clarify
12/19/2008 9:09:35 PM •
Toshiba...
Answered
on Dec 19, 2008
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
