20 Most Recent Sony VAIO VGN-CR515E/B Notebook Questions & Answers
2answers
DVD player stopped working. Why
Welcome to FixYa!
It seems that you are having problem with the optical drive, it maybe the hardware itself or software side, please follow the steps below for you to be able to fix the problem.
1. Click on START
2. Type REGEDIT on the search bar on START Menu on the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Thank you for using Fixya...
11/30/2018 11:29:23 AM • Sony VAIO... • Answered on Nov 30, 2018
Cd/dvd drive not working
DO a Google search and check EBay you should be able to find a replacement at one of these two sites
8/18/2011 6:33:16 PM • Sony VAIO... • Answered on Aug 18, 2011
Unable to find drivers for sony vaio vgn cr515
Hi subbu79,
You can download the Windows 7 Driver for your VGN-CR515E/B Computer model from the below link. Please go through all the download and installation instruction while before installing the Drivers.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR515EB&SelectOS=44
Please paste the link in a new Internet Explorer window and press the Enter Key to open it. Then, you can download the required Drivers and install it in the Computer. Please make sure that you restart the Computer after each installation for the settings to take the effect.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
11/11/2010 1:41:57 AM • Sony VAIO... • Answered on Nov 11, 2010
Not recovery for Vista after installed Windows XP
The Computer is shipped with the Recovery Center, a hidden partition in the Hard Drive. Please restart the Computer and press the F10 key when the VAIO logo appears to access the Recovery Center.
If the Recovery Center is accessible, select Restore C Drive to reinstall the pre-installed Operating System, Applications and the Drivers (restore to factory settings).
If the Recovery Center is not accessible, then the Recovery partition may be deleted. In that case, you can contact Sony Accessories and Parts Center from US at: 1-800-488-SONY (7669)to order the Recovery Discs.
Good Luck!
Thank you for contacting.
7/7/2010 6:56:48 AM • Sony VAIO... • Answered on Jul 07, 2010
My Fan runs very slowly or not at all, core temps
replace the fan.
2/18/2010 5:26:00 AM • Sony VAIO... • Answered on Feb 18, 2010
Sony vaio vgn-cr515e sound system not working
It's because it is using realtech high definition audio. You need to install hotfix from Microsoft KB88811 and then install audio driver.
You can get hotfix from the link below
http://rapidlibrary.com/index.php?q=microsoft+update+kb88811
7/17/2009 2:15:25 PM • Sony VAIO... • Answered on Jul 17, 2009
Sony VAIO VGN-CR515 HARDWARE COMPONENTS DRIVERS
http://esupport.sony.com/perl/select-system.pl
Here's the site you need to visit ....simply answer a few questions on your make and model and retreive all neccessary drivers. Good luck
6/3/2009 8:17:01 PM • Sony VAIO... • Answered on Jun 03, 2009
SOFTWARE INSTALLASION CDS
Check the Sony website; I think you will find a source for your missing software.
9/17/2008 9:02:51 PM • Sony VAIO... • Answered on Sep 17, 2008
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
How can dennythedon3003 help - if only he spoke English
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:39:57 PM • Sony VAIO... • Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu? thanks
11/30/2018 6:38:47 PM • Sony VAIO... • Answered on Nov 30, 2018
Denythedon3003 fixya spam loser - guess what country he's from - maybe Tom can block him
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:25:34 PM • Sony VAIO... • Answered on Nov 30, 2018
Pci modem drivers and audio drivers
Check this Sony's website: Original Drivers Package
10/9/2018 8:31:43 AM • Sony VAIO... • Answered on Oct 09, 2018
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM • Sony VAIO... • Answered on Sep 30, 2018
0answers
Sony VAIO VGN-CR515E/B Notebook Logo
Popular Tags
17 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
software installasion cds
  • Computers & Internet
