20 Most Recent
Philips DVP5990 DVD Player Questions & Answers
Unable to read mkv and avi video files from usb drive on
what error does it give? mine reads avis fine, as long as theyre within resolution limits. same for windows media format. couldnt get the mkv files to work though. the usb drive has to be formatted fat32, ntfs does not seem to work. burning these files to dvd as a data disc is another option. lets you fit 10+ hours of video on the disc vs your standard 2 or 4 hour max limits.
PANDORA WONT STOP BUFFERING ON PHILLIPS 3D BLURAY
buffering is always a problem with the internet connection speed
depending on your carrier and the type of connection usually either broadband or dsl that is your problem contact your provider a or use less internet with other devices when using netflix high bandwidth
The remote does not work
Check the battery + - compartment for moisture or rust connections and used some WD40 chemical spray in a rag and clean it + - battery connections.Wait like 10 mins put battery back in the remote should work again.If not,still have the same problems.The tv remote comtrol CPU chip it is shorted and dead.Or try website Remotes.com to buy a replacement new original remote.
Computors functions
You are having a spyware or virus problem. They are famous for highjacking browsers. You can try using this website to get a free anti-spyware program.
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE Run it and see if help you with your problem. Also run a anti-virus program. You amy have to download a few programs to get rid of all the spyware and viruses. This is normal as ther is no one solution once you have a problem. You can fin a free anti-virus program at www.avast.com This is a very good program for fighting viruses. You can also get AVG anti-virus. Try Spyware destroyer also. Usually it take a combination of these programs to find and get rid of the problem. Also do a clean disc and defrag on your harddrive to clean up any problems left behind by the spyware and viruses. I hope this information helps you with your problem.
No subtitles on data cd
maybe is the problem of format not matched.you can use a avi to DVD video converter,that must be played on the DVD player.i have used a
DVD creator for long,you may have a try of this one.
