20 Most Recent
IBM Lenovo ThinkCentre® M52 PC Desktop Questions & Answers
HD5450
I would listen to how many beeps then search google for how many beeps and whats it mean and a list of codes should come up ... but if you just bought the HD i would return it.. or make sure everything is connected properly
Replace dvd drive how to
Hi Kim,Considering your PC is IDE powered,make sure also your replacement is an IDE powered DVD drive.
- Open the cover pressing on the sides and sliding it backwards.
- Locate the DVD drive.
- Disconnect the power and the IDE Interface cables[wide greyish 40 pin cable] from the drive.
- Disconnect the Sound card cable which is the smallest of the cables.
- Pull the drive backwards and upwards to remove it.
- Now fit the replacement.
- Connect the drive's power, IDE Interface and the Sound card cables back.
- Cover it back and turn it on.
Hope this helps.Thanks!Please rate this answer.
Computer screen upside down
in video settings turn mirror image off (or turn monitor upside down)joking on last bit although it will work
Gigabit ethernet adapter
write down the model number of the adapter go online and search for the driver may take a while but you should find a site offering the driver for free.if it is a fixed adapter the motherboard disc should have the required driver on it.hope this helps
F1 key not function
The best way to troubleshoot is to find another keyboard and test it. Then you would know if its your keyboard having a problem or the desktop/computer
