Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
