20 Most Recent Nikon Coolpix S560 Digital Camera Questions & Answers
I have a Nikon Coolpix s560. I want to shut off
Select "Date Imprint" from the Setup menu and turn it off.
Display the Setup menu by pressing * then select the wrench icon and press OK.
2/23/2022 9:15:01 AM • Nikon Coolpix... • Answered on Feb 23, 2022
The power button is jammed
Normally above problem occurs when small cameras used near sea. High moisture, salty weather and sand accumulation creates above problem. Try a small drop of antitrust spray(WD40) after removing batteries.wait for 20mts operate switch slowly. Other wise switch to be replaced by camera technician.
10/1/2017 2:33:47 PM • Nikon Coolpix... • Answered on Oct 01, 2017
Nikon s560 won't turn on
The same problem here. Please help. Thanks
8/31/2015 8:12:40 PM • Nikon Coolpix... • Answered on Aug 31, 2015
Camera mode takes blank photos
Is the lens cover open? (Make sure battery is fully charged) go into the menu and reset the camera make sure it's switched to auto and try again. I assume you have looked at the photos on a monitor? If they are absolutely black with no noise it's the processor.
4/4/2014 12:29:25 PM • Nikon Coolpix... • Answered on Apr 04, 2014
0answers
How do I get my
Check whether you've put in the battery correctly. There should be some indicator on the battery itself and in the camera for the reight direction.
Make sure, when you try to close the cover firmly bu not with brute force. It should snap in eventually.
6/23/2011 10:05:58 AM • Nikon Coolpix... • Answered on Jun 23, 2011
My Nikon CoolPix S560 has
Yes, the flash can burn out or the flash circuit can short out. You can send it in for service but, since it's out of warranty, it will be very expensive. B&H photo has a refurbished one for $70. If you send yours in, what you will get back is a refurbished one....they do not bother to fix point-and -shoot cameras. Your choice.
6/13/2011 8:54:42 PM • Nikon Coolpix... • Answered on Jun 13, 2011
How do I delete a
to solve this it have many way and each way still not have 100% successful. how you can try .
BEFORE SOLVE IT. YOU NEED TO BE ADMIN.
1ST METHOD.
update your antivirus.
and full scan. It will need more time, how ever if you have time , you can do this.
After several minutes, after complete scan. you can try again to access your photo.
2nd method
you can try delete using winrar software.
normally, we only use it to extract or archieve file rar or zip.
Open winrar, and browse in winrar.
Find file that and delete. it more easily.
rate me if that was succes :) smile always to ****** virus
5/14/2011 6:33:19 AM • Nikon Coolpix... • Answered on May 14, 2011
When i plug the usb cord from the computer to the ...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
4/30/2011 5:09:37 PM • Nikon Coolpix... • Answered on Apr 30, 2011
My computer is not acknowledging
3/20/2011 7:03:34 PM • Nikon Coolpix... • Answered on Mar 20, 2011
I have a nikon s570
Try replacing the battery. If the camera is still draining power from a new battery, call Nikon directly and explain the situation. They might have you send the camera in and send you back a refurbished model.
3/15/2011 12:01:14 PM • Nikon Coolpix... • Answered on Mar 15, 2011
Although my Mac detects my
One way to troubleshoot would be to try using an SD card reader to eliminate any problem with the camera itself.
3/7/2011 4:15:23 AM • Nikon Coolpix... • Answered on Mar 07, 2011
Software download for nikon s560
Hello. try nikonusa.com/support/download .
There you found the software.
Regards
3/7/2011 3:13:09 AM • Nikon Coolpix... • Answered on Mar 07, 2011
Lens comes in and out 3 or 4 times and then closes
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
2/20/2011 11:49:35 PM • Nikon Coolpix... • Answered on Feb 20, 2011
Lost my cd-rom disc for
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
1/27/2011 5:15:22 PM • Nikon Coolpix... • Answered on Jan 27, 2011
My nikon coolpix camera will not show up on my mac
Consider NOT connecting your camera to your Mac.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can Nikon Transfer or iPhoto or any other photo cataloging program.
1/6/2011 6:12:37 PM • Nikon Coolpix... • Answered on Jan 06, 2011
tip
Nikon CoolPix S560
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S560-Digital-Cameras-review-manual/id/23007dj391/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
When i turn on the
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
12/26/2010 6:36:06 PM • Nikon Coolpix... • Answered on Dec 26, 2010
Nikon Coolpix S560 Digital Camera Logo
63 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
nikon coolpix s560
  • Cameras
