20 Most Recent Kodak EasyShare M873 Digital Camera Questions & Answers
Trying to transfer but not being recognised
You don't need a driver. The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/24/2014 4:51:44 AM • Kodak EasyShare... • Answered on Nov 24, 2014
When camera saves a picture, it has severe bars across it. Shows fine in the display before taking the picture. Video is not effected and saves fine. Solution?
Camera needs the typical repairs for this model, These Kodaks are NOT good cameras !!!!!
1/24/2013 9:57:50 PM • Kodak EasyShare... • Answered on Jan 24, 2013
Iturn it on it then goes in and out of focus and
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
8/14/2011 12:30:41 PM • Kodak EasyShare... • Answered on Aug 14, 2011
How do I save internal memory to a card on the
Press the Review button, then the Menu button. Use cursor-left-right to select the Review tab. Use cursor-up/down to select "Copy" and press OK.
4/19/2011 4:57:22 PM • Kodak EasyShare... • Answered on Apr 19, 2011
Lense does not come out when camera is switched on
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
1/26/2011 8:00:56 PM • Kodak EasyShare... • Answered on Jan 26, 2011
My kodak easyshare m873 pics are always blurry
put it on auto,,when u take pics,,
10/24/2010 9:51:46 AM • Kodak EasyShare... • Answered on Oct 24, 2010
I have a Kodak camera Easy Share C643 that has
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
9/30/2010 7:10:28 AM • Kodak EasyShare... • Answered on Sep 30, 2010
When turning camera on lens tries to focus then camera turns off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/2/2010 12:16:44 PM • Kodak EasyShare... • Answered on Jul 02, 2010
My camera says my internal memory is full how do I
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions.
7/1/2010 10:12:03 PM • Kodak EasyShare... • Answered on Jul 01, 2010
I have a kodak easyshare M873.. the clarity of the
hey dude.. easy to find just download from here choose the OS first
5/15/2010 6:40:25 AM • Kodak EasyShare... • Answered on May 15, 2010
The camare will not turn on
Ive got the Same problem I have been told it will make a good paperweight not worth fixing
3/22/2010 12:01:53 PM • Kodak EasyShare... • Answered on Mar 22, 2010
Have an EasyShare M873. The lens will not open
not worth fixing. repair costs more than an new $70 12mp camera
3/9/2010 4:19:38 AM • Kodak EasyShare... • Answered on Mar 09, 2010
I have an EasyShare M873. When I turn on, lens will not extend.
3/8/2010 3:38:10 AM • Kodak EasyShare... • Answered on Mar 08, 2010
I have a kodak c743 with error code #126,1,0,0 and
To remove the error, follow the instruction:-
1) Turn OFF the camera. 2) Remove the memory card from your camera. 3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera. 4) Turn ON your camera.
This will clear your error.
Have a nice day Rating the solution is highly appreciated.
3/6/2010 5:22:02 PM • Kodak EasyShare... • Answered on Mar 06, 2010
My Kodak EasySharecamera cannot remain on. Pressing the On buttom
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
1/26/2010 2:24:56 PM • Kodak EasyShare... • Answered on Jan 26, 2010
Camera goes on and off immediately
Even though they are charged thay might have a fault. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
1/26/2010 2:15:15 PM • Kodak EasyShare... • Answered on Jan 26, 2010
2answers
Kodak easy share m873 powers on tries to focus
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
1/21/2010 12:00:31 PM • Kodak EasyShare... • Answered on Jan 21, 2010
M873 wont open properly and turns it self off
This could be due to faulty mechanism in the lens.. due to physical shock.. one cannot service it by house hold tools.. needs to be serviced..
1/21/2010 8:06:26 AM • Kodak EasyShare... • Answered on Jan 21, 2010
Whenever I turn camera on it immediately turns off
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
1/18/2010 11:19:32 AM • Kodak EasyShare... • Answered on Jan 18, 2010
My kodakeasyshare M873 Won't charge ?
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
12/21/2009 12:18:35 PM • Kodak EasyShare... • Answered on Dec 21, 2009
Kodak EasyShare M873 Digital Camera Logo
30 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
when turning camera lens tries focus
  • Cameras
