20 Most Recent
fedora Linux Operating System Questions & Answers
How to solve undetect usb device? (using
Go to link
http://www.troublefixers.com/my-computer-does-not-detect-pen-drives-and-other-usb-devices-like-ipod-or-external-hard-drive/
Here u will get root of your prob
AFTER UPDATE problem MANJARO LINUX between 15 and 22-09-2016
Dbus problem after update Manjaro linux system ffor those who have manjaro
22-9-2016 having an update i found a problem with starting with root privileges from kde desktop kuser and krusader and more tools that will not starting up.
all problems with dbus from terminal you can start up and export $(dbus-launch) and after you can start krusader with root privileges and also from the startmenu also kuser part of kdeadmin after export $(dbus-launch) froma terminal.
But i have read much stories of other linux tools and some of them removed idden file .kde4 so it will return with system defaults back , andsome of them have luck a time of 2 years ago , but now its 2016 and Manjaro is a very special and good stable linux BUT nothing was started with root privileges from the kde desktop like krusader or kuser and other tools for root sudo also ot even . there was 1 little problem that was a part and that was the dbus session....... so start your konsole and sudo pacman -S dbus-x11 and you will see a conflicting package dbus arrived thats installed ?? it asked you to remove dbus and say yes so dbus out and dbus-x11 installing and after that it works al as before correct .
perfect.
Linux dvd player codec
yum localinstall --nogpgcheck
http://download1.rpmfusion.org/free/fedora/rpmfusion-free-release-19.noarch.rpm http://download1.rpmfusion.org/nonfree/fedora/rpmfusion-nonfree-release-19.noarch.rpm
NOW you will install all codecs, yeah
yum -y install gstreamer-plugins-bad gstreamer-plugins-bad-free-extras gstreamer-plugins-bad-nonfree gstreamer-plugins-ugly gstreamer-ffmpeg
yum -y install gstreamer1-libav gstreamer1-plugins-bad-free-extras gstreamer1-plugins-bad-freeworld gstreamer1-plugins-base-tools updates gstreamer1-plugins-good-extras gstreamer1-plugins-ugly gstreamer1-plugins-bad-free gstreamer1-plugins-good gstreamer1-plugins-base gstreamer1
ffmpeg
yum -y install ffmpeg
Mencoder
yum -y install mencoder
ffmpeg2 theora
yum -y install ffmpeg2theora
Mplayer
yum -y install mplayer
Play dvd, yeah
yum -y install libdvdread libdvdnav lsdvd libdvdcss
Also you can use
PostInstallerF
or you can use http://www.mplayerhq.hu/design7/dload.html this to play movies..
I need Fedora 15 drivers for a MultiTech MT5634ZBA modem... ugg.
You must have the most recent kernel, 2.4.2 or higher. You will also
need specific modules for installation, they are explained below. The
MT5634ZBA-USB has been tested successfully in Mandrake 8.1 and RedHat
7.2. Please read the whole document, as some steps depend on how the
Linux system was built. You need to select the USB Modem (CDC ACM)
support kernel option. If you build as modules, you need to install the
acm.o option. You need to set up the device node entries for the various
modems. You can use up to 32 modems with this driver. Use the following
commands to set up the first four:
mknod /dev/usb/ttyACM0 c 166 0 mknod /dev/usb/ttyACM1 c 166 1 mknod /dev/usb/ttyACM2 c 166 2 mknod /dev/usb/ttyACM3 c 166 3
You should now be able to use a terminal emulator program to attach
to this device and connect to your modem or other terminal device. If
your current version of Linux has the ACM driver compiled into it, then
you're ready to roll. If it has the driver built as a module, then
you'll have to enable the driver with the following command:
modprobe acm
At this point, you may have to unplug the modem's USB cable and then
plug it back in (this isn't necessary if you're using kernel 2.4.X). You
should see the modem's lights come on. If you see some activity lights
on the modem, type the following:
lsmod
This command will display a list of loaded modules. The ACM module
should be displayed as loaded. Now that you've got the driver loaded,
you need to set up the device node (in /dev) for the modem. You can use
up to 32 modems with this driver, but most people will only need to
configure one. To set up a modem, use the following command:
to this device and connect to your modem or other terminal device. Going
one step further, you can set up a symbolic link from /dev/modem to the
ACM modem device. This is accomplished by using the following command:
ln -s /dev/usb/ttyACM0 /dev/modem
That way, KPPP and related applications can all refer to the modem
as /dev/modem without caring what type of modem it is.
Models: MT5634ZBA-USB
If the above document doesn't get you going, send me a private email &
I'll have a Multi-Tech Systems, Inc. Technical Support Rep. get in touch
with you ;-)
CAN'T CONNECT TO INTERNET
Check that you network card is installed or not if not then install .
after installing you need to configure it ip address which is provided by you ISP provider that's it. please let me know if you are facing any issues..
What are examples of applications
Ditto rjivaro, except the windows emulation part. Most applications can be replaced with actual linux compatible ones, however there a some (mostly games) that can not. Wine is your friend for games except that you will have a reduction in frame-rate as the system has to convert dx to opengl and back again. Best to keep a small windows install for game playing. Non linux games anyway
Installing new os
Installing any os ahould not be affected by a virus. Download the iso, burn it out or flash it to usb. Boot from the disc and follow the prompts. Viola, new os and no virus.
What is a Linux Operating
A "Linux operating system" is any collection of programs that combine to make an operating system using the Linux kernel.
How we use linux complier to edit, debug and
I'm assuming your using some form of C.To edit, you can install command-line based editors like emacs and vim, or use gui editors such as gedit or kate. There is also IDE options like EclipseTo compile is relatively simple, most linux distros come with a builtin version of gcc and g++ (the c compiler and c++ compiler); more information here: http://pages.cs.wisc.edu/~beechung/ref/gcc-intro.htmlTo debug, it is a little more complex and you may have take some time to properly learn the workings of a debugger. If you're using Eclipse, I'm pretty sure there's a builtin debugger in that which would be rather simpler to use than the alternative I use: gdb (http://www.unknownroad.com/rtfm/gdbtut/gdbtoc.html).
What is the features of fedora Linux operating
Fedora is an open-source Operating System which means that it is free to use, in that it does not cost any money and it gives you the freedom to manipulate or modify the software as you wish.The requirements needed to install Fedora are also relatively low, allowing it to operate on older hardware. From Fedora's website (http://fedoraproject.org/):
- 400 MHz Pentium Pro or better processor (comparable AMD, Cyrix, and VIA processors also acceptable)
- At least 768 MB memory (RAM), 1 GB recommended for best performance
- 10 GB disk space / storage
Fedora is also considered to be much more secure of an OS than Microsoft Windows or Macintosh.Fedora also has a large selection of software available that will allow you to do a multitude of things, such as watch movies, view and manipulate photographs, listen to music, create documents, any much more.
