20 Most Recent
Kohler K-T462-X4V-CP Memoirs Rite-Temp Pressure-Balancing Shower Faucet .... Questions & Answers
My heater stops working in the middle of the night
the Model number you gave is for a Shower Head what do you mean it doesnt heat... it only conrtols the water temp by BALANCING the hot and cold water inlets does NOT heat anything if your water is cold then check another PLAIN faucet to see if your water is the same temp( cold) if it is the hot water from water HEATER is cold nothing to do with faucets
11/22/2009 1:51:06 AM •
Kohler...
Answered
on Nov 22, 2009
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
