20 Most Recent
Makita HM1810 Electric Demolition Hammers Questions & Answers
What is (60 g) of grease
181490-7 grease 30g 1 pcs complete be shure there are no cured o-rings or bad gaskets .
188015-8 its the maintenance kit for the service it contains already this 30 grams grease, where come 60 grams advise ? i like also to use some more grease by this heavy kind of hammers.
But tools like Hilti with liquid (oil) lubrication and very tight tolerance ball bearings if there is to much (turmopol) oil used it will be damaged, and too little oil also its calculated. I cannot give garantee that 60 grams are advised by a makita service, if you order a maintenace kit ask the seller about why it only contains 30grams. The information to use 60 grams ? doubt.
I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Tool wont scrape
254031-3 pos14 part inlay key can be damaged pos 11 drive rod 315146-2 can broken IF mechanical damage or dried out by leaking gasket / orings.
For better repair use after a repair of some parts an maintenance kit
193394-1
If the working hours are on it, but also after an repair on other parts because leaking tools can be dried out and give cured o rings in a very short time by building up overheat temperature inside and will not build up pneumatic power it will not do the job and is not good for physical strain.
How to grease a makita mt m8600 demolition hammer
Order an maintenance kit for it , when the working hours are on the tool , all given parts in the kit must be replaced its not a good idea to only grease it, the tool should not leaking by the chisel. then there will be a bad break-force and give a long working job..
HOW GOOD IS H65SB2 HITACHI?
As long as its last and the endurance of the worker in first place .
Its better then use rotating hammers at a long lasting working order , because of the price the choice of a demolition hammer is always a great difference because of the time you can spend , there are much Chinese models look a like this hammer its popular also bosch models you will see .
chinese demolition Google zoeken
