20 Most Recent
LG WM-2032H Front Load Washer Questions & Answers
Washing machine dampers
damper is stiff. i would look at the springs that hold the tub if you take them off a bad one won t close all the way up also check leg mounts for weak medal
I have an LG-WM2032HS front
Sounds like all you need is a new pump motor. Pretty common issue. Fairly inexpensive motor. About $30+ on amazon. Check out repairclinic.com or appliancepartspros.com for part numbers and repair videos. Good luck.
Load pop when running ,shuts down,smoke from back,burning electrical
You have a tub "Balance" bearing that is Shot! Goner! Dead! And your Tub may be a goner too! Depending on the extent of damage, you said you saw SMOKE! I never seen smoke from a washer unless someone throws a Concrete Block Stone in one on You Tube! ON PURPOSE! You have to weigh the age of machine vs the price of a new/USED one. If your machine is over 7 years old. Get a new One! Not a LG for goodness sake. Get a Whirlpool or a Maytag. I just bought a used one (Whirlpool) for $150. Still works 2 years later right next to the Dead $1600 LG I bought 6 years ago! The man I bought it from is in Rosamond, Ca. right by Edwards AFB. He has a garage full of them and guarentees his machines. There are a lot of people that do this. New is Not always the best! If you need further help, reach me via phone at
https://www.6ya.com/expert/steven_b77d19396bfe2249
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power
Check
to see whether power is getting to the washing machine. Is it plugged
in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If
the lid switch is defective, your washer can't spin and may not
function at all. The switch is inside the washing machine main housing
near the door frame. Often you have to raise or open the top or front of
the washer to get to the switch. If it's defective, you need to replace
it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page.
Some
machines have a special lid-switch fuse near the lid switch, inside the
control panel. If this fuse blows, the unit won't fill with water until
you replace the fuse.
My LG Tromm Ww2032hw washer
Hopethis helps.. A 4 thumbs-up rating is greatlyappreciated for answering your free question. Thank you in anticipation.. Good luck! ;)
We have an LG wm2032hs.
I believe you may have put it in the second largest container (Usually marked by a bucket with a 1 in it), this is for Pre-wash. So you will have to select Pre-wash on the Facial panel. It will then take the bleach first and after washing with it, the machine will rinse and drain it away - and continue with the normal wash and whatever you may have also left in the detergent box.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up, and a testimonial will do nicely :-)
Doesn't spin in spin cycle
Open the access door at the lower left on front of the machine. Use the hose there to drain the water out of the machine. Unscrew the big knob there and pull out the attached filter. Clean out filter and replace. If filter was clear, replace drain pump motor.
