20 Most Recent LG DLE5977 Stainless Steel Electric Dryer Questions & Answers
Dryey makes loud noise on startup
Check for excellent air flow. Could be an object caught in fan.
3/8/2018 5:19:47 AM • LG DLE5977... • Answered on Mar 08, 2018
Must let dryer cool down before it works again
What is the manufacturer of your dryer?
6/28/2017 4:58:06 PM • LG DLE5977... • Answered on Jun 28, 2017
How to reset lg dryer dle5977s. It won't turn on at all and want try this first
Best thing to do is to leave it unplugged for awhile, at least 15-20 mins then go from there. I'm not sure there is a reset. If there is it should be in the manual that came with the unit, if you don't have the book there are alot of websites that have copies for a small fee.
9/3/2015 9:32:03 PM • LG DLE5977... • Answered on Sep 03, 2015
My LG dryer makes a loud "buzzing" noise and won't start up, as if the motor is seized. How can I confirm?
The only way is to remove the back panel and do a visual check but be careful...
2/13/2015 12:46:50 AM • LG DLE5977... • Answered on Feb 13, 2015
What is the issue when the drum will not turn when dryer is on
The drum belt is probably broken or off the motor shaft.
7/21/2014 7:38:23 PM • LG DLE5977... • Answered on Jul 21, 2014
0answers
Once dryer heats up towards end of cycle, drum quits spinning and won't restart, only hums
It could be a couple of things there could be lint on the motor shaft which will cause the motor to run hot and make to over temperature switch open or the hot air output on the back of the dryer may be plugged, just before or around the blower. Good luck
3/25/2014 2:05:57 PM • LG DLE5977... • Answered on Mar 25, 2014
Crack in drum at seam
We had the exact same problem with our LG dryer but the crack was in the front near the door. The service tech as well as the engineer from the LG R&D department both agree that it is a manufacturing defect...the result of a poor welding job by LG. The service tech replaced the dryer tub today and the dryer is as quiet as when we first bought it. I paid for the part and the repair myself to get it fixed quickly. The service tech said to use it with the crack could be a fire hazard since the heating element is open under the tub. However, the service company we use will reimburse me for the cost of the part if LG agrees to reimburse them. I am in the process of working with the resolution department to get them to agree to pay for this part. It is no longer under warranty but since there engineer has agreed that it is a manufacturer defect, I am hopeful I will get my money back!
1/11/2014 8:14:52 PM • LG DLE5977... • Answered on Jan 11, 2014
Smell something burning
a drum wheel make be frozen causing it to smell and have black residue from the rubber. here is a video of how to check and disassemble http://www.youtube.com/watch?v=Sy_ZK5f-WS8
12/19/2013 7:54:44 AM • LG DLE5977... • Answered on Dec 19, 2013
CHECK Filter blinks when power on. It will not let
the check filter isnt an error but a reminder. it will always blink regardless to remind you to clean the filter
10/31/2013 12:03:34 AM • LG DLE5977... • Answered on Oct 31, 2013
LG DLE5977s electric dryer drum not turning when warm
Could be one of the "overheat thermostat switches" has failed, or is failing.Could also be a big buildup of lint inside the machine (where you cannot see it) causing the switches to trip. In the back or the bottom of the machine are from 3 to 7 "overheat thermostat switches" that are put there to prevent fire. When the get hot, if they are bad, they will shut off the dryer until they cool off. Kinda sounds like one is "trippin' ". If you choose to fix it yourself, you'll need a good electrical test instrument and several tools to take it all apart. A question to "fixya" might get someone to tell you how step-by-step.Be blessed.
3/28/2013 3:27:30 AM • LG DLE5977... • Answered on Mar 28, 2013
2answers
LG Dryer DLE5977B makes a
replace rollers on drum
12/21/2012 4:44:37 PM • LG DLE5977... • Answered on Dec 21, 2012
The safety thermostat switch keep breaking (opening) every 3 to 4 moths don't know why
The sure don't make things like they use to. The only thing I would think is that the drier is getting too hot or the switches are poorly made. Might check the exhaust duct or see if you can find a better quality limit switch.
4/4/2012 2:08:30 AM • LG DLE5977... • Answered on Apr 04, 2012
Drum does not turn
Hi.Check door switch, drive belt and drive motor. Door switch can be tested using an Ohm meter, drive belt is tested visually and the motor can be Ohmed or energized.
12/1/2011 1:28:27 PM • LG DLE5977... • Answered on Dec 01, 2011
The dryer is not drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
6/30/2011 12:52:09 AM • LG DLE5977... • Answered on Jun 30, 2011
I have an electric dryer,
You may want to call an Electrician and see what the cost would be to hook up 240 volts.Hope this helped.
6/29/2011 5:23:06 PM • LG DLE5977... • Answered on Jun 29, 2011
I push the power button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
6/19/2011 9:11:26 PM • LG DLE5977... • Answered on Jun 19, 2011
E1 error code is on
You have a bad thermistor and needs to be replaced.
6/16/2011 3:52:33 AM • LG DLE5977... • Answered on Jun 16, 2011
LG DLE5977 Stainless Steel Electric Dryer Logo
51 questions posted
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
severe noise drum jammed turn lg dle
  • Dryers
