20 Most Recent Schiller Cardiovit At 1 Ecg Machine Questions & Answers
What's the difference between a single channel
a single channel records one leads at a time and a three channel records threeat a leads time
2/19/2019 11:35:12 AM • Schiller... • Answered on Feb 19, 2019
I have a problem with Schiller AT-101, the problem is "check paper".. can u help me out ?? thanks
try settings printer setup under paper settings might give you a list of papers to enter. failing that removevpaper from tray and re insert . i think it is in the paper settings you will find the answer.
10/30/2018 6:52:27 PM • Schiller... • Answered on Oct 30, 2018
2answers
Electrode lead off light indicator
Hi I have the same problem.. of you have already solved the problem please let me know
4/10/2017 8:36:43 AM • Schiller... • Answered on Apr 10, 2017
Schiller at-1 says lead off
Check the leads. If any of the Leads is open the this problem can occur. You have to check the continuity of each cable for the lead end to socket. All leads should show a resistance of 10KOhm If you wish to get some details About schiller AT1; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/13/2016 4:01:01 PM • Schiller... • Answered on Jun 13, 2016
I have an at1 schiller
hi,
You have to check two things. First you have to check the patient cable, and have to check is its electrodes are properly cleanded or not. if any one of the lead or the electrode have some problem then the machine will stop printing.
Second thing the battery inside the machine. its a 12V 2.3AH battery. If availabel try to replace the same. To replace the battery you have to oppen the machine.
ok
4/17/2015 2:30:23 PM • Schiller... • Answered on Apr 17, 2015
tip
How to set up
Check the video to know how to setup Schiller AT 1 and AT2. Electronics Equipment Repair Center
tip
Part list
Part list and part number Schiller AT 2 ECG EKG. Case, Upper, AT-2 (complete w / keybrd) Case, Upper, AT-2+ (complete w / keybrd) Case, Lower, AT-2 / 2+ Case, Lower, AT-2+ w / mem / tx Label, Instruction, Clear Overlay AT-2 only Label, Instruction, Clear Overlay AT-2+ only Paper, AT-2/AT-2+, Tray Kit Assy, Paper, Lid AT-2 / AT-2+ Assy, Paper, Rel, Catch, AT-2 / AT-2+ Assy, Paper Tray, Holds Paper AT-2 / AT-2+ Paper, Feed Roller, Black AT-2 / AT-2+ Assy, Thermal Print Head, AT-2 / AT-2+ Paper, Mark Detector AT-2 / AT-2+ Thermal, Print Head Springs (2-required) Assy, Paper Drive Motor AT-2 / AT-2+ Electronics Equipment Repair Center
2answers
Don't know the difference between a one channel and three channel
Bionet CardioCare 2000 Interpretive EKG for around $1200 is a good user friendly model...
below is a link to shop for new & used machines
http://www.cardiacdirect.com/index.php?page=products&id=1
I hope this is helpful.
5/27/2013 11:11:34 AM • Schiller... • Answered on May 27, 2013
LIGHT ON AT AC
hi,
You machine have complaint in its main board. Years back i got a machine with same complaint. After a lot of serch i found a track break it its main board, because of some sort of chemical reaction it the tracks. Search for the same in your machine. Just trace the two tracks from the power on switch. One end of it will be common connection for all the other switches And the other end of the power on switch will goto the power supply. As a multlayer pcb it will be very difficult to trace the track. Anyway just try it. Also check the SMD (surface ***** device) fuses in the power supply stage. Also check the power stage for any track break. If you are not able to do this then there is only one way contact the manufacture for support. It will be very expensive because they will tell you to replace the main board.
ok
3/18/2013 9:58:30 AM • Schiller... • Answered on Mar 18, 2013
ECG Schiller AT1 shuting down in work
Most likely needs a new battery. Can be ordered from R&D batteries.
3/18/2013 9:57:07 AM • Schiller... • Answered on Mar 18, 2013
The schiller at-1 ran out of paper, I put some
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
3/18/2013 9:56:24 AM • Schiller... • Answered on Mar 18, 2013
ECG AT1 not operate power
Problem in Battery, Replace it
3/18/2013 9:53:14 AM • Schiller... • Answered on Mar 18, 2013
2answers
Schiller AT-1
I have a problem with ECG Schiller AT-1. In auto mode, it prints nothing but in manual mode it works properly. Could you help me solve this problem
3/18/2013 9:51:31 AM • Schiller... • Answered on Mar 18, 2013
Hi i am ECG technsition i face some trouleshooting
hi,
replase the battery or ur ecg machine. is a regular complaint with AT1.
OK
3/18/2013 9:49:11 AM • Schiller... • Answered on Mar 18, 2013
Battery needs to be replaced, my understanding is
hi I don't think is there is any calibration issue while replacing the battery. For replacing the battery you have to open the ECG machine. its a 12v 1.2Ah battery. It will hve to plugs remove the two plugs and remove the old battery. install the new one in position and reconnect the plugs. only thing you have to remember is do not interchange the positive and negative terminal. ok
3/18/2013 9:46:56 AM • Schiller... • Answered on Mar 18, 2013
Booting problem, my ecg machine
hi,
You have to replace the battrey of the ECG machine. Even if you are connected the power the machine works on battery. The mines power is used only for charging the battrey. If the battery is faulty then then machine will power off by it self. Its a 12v 1.2Ah battery. For replacing the you have to open the machine. You can't access the battery externally.
You can find the battery in the following link.
http://www.foremostequipment.com/index.cgi?item=FME-26566&q=Spirometry&s=CATEGORY
ok
3/18/2013 9:44:04 AM • Schiller... • Answered on Mar 18, 2013
Schiller Cardiovit At 1 Ecg Machine Logo
Popular Tags
43 questions posted
Top Schiller Medical Experts
john h
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Schiller Medical Expert? Answer questions, earn points and help others
View Most Popular
Schiller Medical
  • Schiller Medical
Most Popular Question
schiller 1 says lead off
  • Medical
