20 Most Recent
LG LB8000ER Air Conditioner Questions & Answers
My A.C doesn't turn on
cause don't use an extension cord. probably fried the gfi or burnt other wires if you have a meter just test it
My motor compressor thrifts every 5 mins.
If you have a low pressure switch on your air conditioner it's opening and closing, because you don't have enough refrigerant in the system or it's cycling on the thermal overload in the compressor because it's getting hot.
You need to charge your system to approximately 12° to 15° superheat not by pressure.
Ac doesn't throw cold air
hello friend, All the compressor work in above 190 v. please additional fitting in voltage stabilizer okkkkk
Air conditioner not working properly
You can pull the inside of the unit out of the case to inspect the back coils mainly to see if there is any blockage. Note the screws on the bottom of the housing the holds the coils take the screws out and very gently take the coil and move out a little. It will flex enough to clean the coils. Just don't hit it with very high pressure water cause it will bend the fins that go around the coils. I have done a bunch of window units this way and you would not believe the difference it makes. Let unit dry out and re-assemble. Let me know if you need anything else.. ken
Air not cold
If you are always using it, yes it could be. The heat it produce helps in its normal wear and tear. Corrosion is one and dirt helps. Freon could stay in the system as long as it is not getting any break or hole.
If freon is out of the case. Unit not getting cold, the fault could be dirty air filtter, dirty exchanger, dirt in the system itself, or clog. And also you cannot negate it thermostat, could be its setting or actually faulty. And compressor fault.
Air Unit turns on...compressor works, fan turns on and then shuts off?
Let me guess you drove it home on its side in your back seat and then plugged it in?
Or like many stores with a surplus of product and limited space, there are some units that are stored on their sides by idiot employees, or ones that don't care they just want to get the freight put away.
All of which will more than likely result in a dead air conditioner, refrigerator, or dehumidifier if the unit is not upright overnight before use. The refrigerant is also acts as the lube for internal parts and when stored improperly will all be located in the coils, and not in the compressor where it needs to be. You plug it in and the unit will overheat and die.
Either that killed it or it was DOA, go back and exchange it. Why bother troubleshooting something you can exchange? If you did drive it home on its side don't tell them that, unless you are that guy who didn't put 50:1 in his lawn mower.
Hack
Troubleshooting
first I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
Electical
if its electronic controls verify the fuse if it's manual controls the selector switch shorted out.
New AC thermostat setting creeps up when running the Timer Mode
This should be checked by a professional because several things could cause this. The good news is that it is under warranty for in home service. If you live in the US and need help finding someone for service let me know. Would appreciate a solved rating if you have no further questions.
My LG air conditioner is saying water fl what is that and where can I find it? I cannot find the book.
The FL error usually means that there is excess water in the drain pan. Look for the drain plug cap at the bottom of the back of the air conditioner. Remove the cap and tilt the air conditioner so that any water in the drain pan will run out. If the room is extremely humid and the air conditioner is set to Cool, this is normal. To reduce the water level issue, set the fan speed to Low. If the air conditioner is in the Dry (dehumidifying) mode, try setting it to Cool. Alternatively, consider using a hose if your unit allows for a continuous drain.
Unplug the air conditioner for at least 10 seconds to reset the unit if the error persists. If the drain pan is dry or the error recurs before more water fills the drain pan after the reset, then the air conditioner needs service.
Please add a comment with the model number of the unit if you need help finding the drain pan cap. I hope this helps.
I have error code ch 09 displaying on my
The error codes are not all the same. They are different for different models.
THIS IS NOT A SOLUTION....
This is a "Clarification request"
Can you please locate and post your LG model number here so we can help you properly and professionally.
LG air conditioner
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Also What is the model of your air conditioner. With out that information i cant help you with your ac repair problem
Check us out online at
AC Service Delray Beach Fl
