20 Most Recent LG LS-L1210CL Mini Split Air Conditioner Questions & Answers
2answers
My indoor blower is not working it blinks 8 times
This alarm state is a CH08 alarm. Which indicates that the indoor unit fan motor has a locked rotor. Solution is to check the indoor fan capacitor and replace or test the windings of the indoor fan motor. Note: the indoor fan motor is a BLDC fan motor and can not be replaced with any other motor. It runs of a voltage regulated frequency.
8/13/2022 6:29:08 AM • LG LS-L1210CL... • Answered on Aug 13, 2022
LG split unit CH 21 Fault. Indoor unit shuts off.
My answer is CH 21 error show in Display
6/15/2022 1:45:18 PM • LG LS-L1210CL... • Answered on Jun 15, 2022
4answers
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
10/28/2020 6:09:40 PM • LG LS-L1210CL... • Answered on Oct 28, 2020
LG gold model KS-H186KLA4 remot maual please
I have the same model, I need to replace the capacitor but I can't find the valve of it
6/18/2020 12:36:24 PM • LG LS-L1210CL... • Answered on Jun 18, 2020
2answers
F8 dispaly error in blue star split ac
hello, i also find this problem in my bluestar ac then i callled authorized service man . then he did these steps :-1> Replace the sensore ( you will find inside the ac wich will be red or brown in color)2> then check wheather the wire is in good condition or not means is it working or not.3> then clean the outdoor unit filters and coils,4> and check the proper supply of electricity..
12/19/2019 1:45:09 PM • LG LS-L1210CL... • Answered on Dec 19, 2019
I cant find a manual
You can down load from www.lg/airconditioner.com
2/3/2019 6:31:15 AM • LG LS-L1210CL... • Answered on Feb 03, 2019
2answers
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
11/27/2018 1:39:24 AM • LG LS-L1210CL... • Answered on Nov 27, 2018
2answers
Displayed F8 error
The F8 Fault means that the Temp sensor in the indoor unit that goes into the cooling coil is faulty.
8/8/2018 5:37:06 AM • LG LS-L1210CL... • Answered on Aug 08, 2018
0answers
I moved into my room
You can check LG's website on Air Conditioners that they manufacture at: http://www.lg.com/us/air-conditioners. you may be able to find a number where you can call them for further support. But I would check that website first. Do you know the Model/Serial Number of your unit? This is usually located on a metal piece attached to your unit. Having the correct Model/Serial Number of your product will help narrow your search for manuals to your question.
12/27/2017 8:25:36 AM • LG LS-L1210CL... • Answered on Dec 27, 2017
2answers
I have C7 error on an LG 9000 heating and cooling
C7-Split compressor over current. Check condenser. If full of dust, clean it. Check rpm of fan motor. If less rpm replace capacitor.
9/20/2017 11:10:54 AM • LG LS-L1210CL... • Answered on Sep 20, 2017
0answers
4answers
Gree air conditioning unit turns itself off and
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
12/15/2016 11:43:05 AM • LG LS-L1210CL... • Answered on Dec 15, 2016
DEFY AH12HG F6 ERROR CODE
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset Air Conditioning Coral Springs
8/15/2016 10:57:41 AM • LG LS-L1210CL... • Answered on Aug 15, 2016
2answers
IN WHICH AIR-CONDITION CONTACTOR COMES? I DID NOT SEE YET FROM 1 TON TO 2 TON AC.
If im understanding, you need a 40va 2 pole contactor If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
8/3/2016 3:43:14 PM • LG LS-L1210CL... • Answered on Aug 03, 2016
2answers
WANT TO KNOW THAT IN MINI SPLIT INDOOR UNIT THERE IS THERMISTOR WHICH WORK CONTROL THE COOLING?
Thermostat control the room temperature base on it's setting temp.
7/29/2016 3:11:54 PM • LG LS-L1210CL... • Answered on Jul 29, 2016
TELL ME ABOUT THAT IN MINI SPLIT INDOOR UNIT THERE ARE 5 ELECTRICAL TERMINAL JACK SO WANT TO KNOW THAT WHICH IS THE INDOOR AND WHICH IS THE OUTDOOR WIRING POINT COULD YOU HELP ME PLEASE?
Power terminal connection (Left to right)
L= line
N= neutral
Ground
Then
Next two
For outdoor unit
Line
Neutral
7/29/2016 2:03:23 PM • LG LS-L1210CL... • Answered on Jul 29, 2016
CAN I USE CLEANER FOR SERVICE THE INDOOR AND OUT DOOR UNIT, CLEANER HAS CHEMICAL SENSITIVITY THIS WILL BE GOOD FOR UNIT OR NOT?
find an air conditioner service shop in your area as there are non caustic products available to use to clean the fins on the evaporator and condenser places that sell compressors , driers, evaporators condensers to the air con trade will be the best place to go to I use a product called viper E+ enzyme power which you spray into the fins of the units and it actively cleans for hours it is a non rinsing cleaner made by refrigeration technologies part no rt350g site www.refrigtech.com not cheap but very effective
2/13/2016 9:46:18 AM • LG LS-L1210CL... • Answered on Feb 13, 2016
WHAT IS THE MAXIMUM CAPACITY OF STARTING CAPACITOR AND RUNNING CAPACITOR, AND WHICH CAPACITY RUNNING CAPACITOR WILL BE SUITABLE FOR 1.5 TON AC?
you can't mismatch capacitors on a unit. cause premature failure of componente in system
8/8/2015 5:09:17 PM • LG LS-L1210CL... • Answered on Aug 08, 2015
LG LS-L1210CL Mini Split Air Conditioner Logo
342 questions posted
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
lg split indoor fan runs non stop
  • Heating & Cooling
