20 Most Recent Pride Go Chair Travel Power Chair Questions & Answers
I would check the weight limit on the chair first ,You should be able to see that in your handbook given with the chair.
Second I would see about load testing those battery's ,Go into a auto parts store ,or battery store if in fact you don't own a load tester. make sure both battery's can take a load if not that may be your problem.
Good luck happy to help.
Pride Go Chair... | Answered on Oct 07, 2017
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Pride Go Chair... | Answered on Dec 20, 2016
I want to thank you for the superb post!! I surely liked every bit of it. I've bookmarked your internet site so I can take a appear at the latest articles you post later on.
<a href="https://www.wheelchairindia.com/1194/Pride-Go-Chair">Pride Go Chair Travel Power Chair </a>
Pride Go Chair... | Answered on Mar 21, 2016
This happens to me too it's the drive switches at the back you need to put elastic bands around them so that they don't come out
Pride Go Chair... | Answered on Oct 23, 2015
VSI is the controller under the joy stick. Water will ruin the electronic circuits . The controller is expensive new. You can find rebuilt ones cheaper or can have yours rebuilt. Check your local mobility service shop or on line repair facilities.
Pride Go Chair... | Answered on Feb 24, 2015
Check the battery connections to the wire ends for corrosion and tightness. Take the wires off the battery and remove any obvious corrosion. Take a knife blade and make the wire end shine and the same for the battery terminals. Reassemble the wires to the battery and tighten.
This is what I found - $549+shipping
http://www.monsterscooterparts.com/4-key-50-amp-vsi-joystick-controller-inline-connector.html
There was also an Amazon listing for $479, but the distributor looked a bit shady.
Pride Go Chair... | Answered on Jul 07, 2013
I took my totally discharged batteries into an auto supply store and they left them on their charger overnight. There was no cost for that service and the batteries came back to life and have lasted an additional 6 months. I just replaced them with 12V 15Ah batteries and am getting much better performance now. The total cost for the new batteries was about $70, including delivery.
Pride Go Chair... | Answered on Oct 23, 2012
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File to view via an Adobe Reader.This should be a great help to you.Hope this has helped,i am disabled myself.Colin.
Pride Go Chair... | Answered on Aug 09, 2012
Please visit:www.alldatasheet.com its free Colin.
Pride Go Chair... | Answered on Feb 07, 2011
You can if you want to...
50-80$ sounds a bit better ,It basically a pug and play deal shouldn't take more than an hour
Pride Go Chair... | Answered on Jan 24, 2011
Pride Go Chair Travel Power Chair Logo
32 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
battery discharged
  • Health & Beauty
