20 Most Recent
Kohler K-11470-0 White Wellworth Complete Solution round-front toilet with Questions & Answers
The toilet has been leaking slowly and it's trying
hold the flapper down and see if it stops leaking but it is almost positively the flapper. turn the water off, remove the old flapper, adjust the chain on the new flapper to the length of the old flapper, wipe the port area where the flapper seals to remove residue, install new flapper.
How can I adjust the float
what happens is the float is not staying open for long enough, by shorting the chain that goes to the flapper might help but you can only shorten it so much or the flapper does not close all the way then the toilet is just running and running. No you don't want that so the other thing you can do that might work is when you go to flush the toilet just hold the handel down for 5 seconds this will keep the float up and open for the Right amount of time. Other wise the other way to fix it witch is a old school trick is that you need to find a nice small piece of foam, witch floats and is about the size of a old half dollar and as least half inch thick, you place that on the chain that goes to the flapper so when the toilet is flushed the flapper will float and stay open . IF you do this just make sure to use a good piece of foam and secure it properly where it wont come off the chain.
Seems like it could use more water flapper closes
IT DEPENDS ON WHAT FIND OF FLAPPER YOU HAVE ,SOME COULD BE AS EASY AS SHORTING THE CHAIN THAT HOOKS TO THE HANDLE,OTHER YOU MIGHT HAVE TO SPIN THE FLAPPER TO ADJUST HOW LONG THE FLAPPER WILL REMAIN UP
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
