20 Most Recent Elkay LK58 Drain Questions & Answers
Drains Technical Question
Plumbing codes call for a gap between potable water and a drain. This usually looks like the distance between the faucet and the top of the sink or bathtub (one inch or more). Without the "gap", waste water could siphon back into the drinking supply. This "does" happen in situations where a city main is shut off causing a drain-down of the system with plumbing that has been done improperly. Sometimes it is a hose left in a mud puddle, or maybe a hose lying in bleach water. People have died this way. The plumbing code helps protect the general public from these dangers. Current improvements include antisiphon faucets for garden hoses, the air gap for the dishwasher, proper installation of water heater T&P relief drains, and backflow preventers for irrigation systems.
8/27/2008 12:30:18 PM • Elkay LK58 Drain • Answered on Aug 27, 2008
How do i remove the stem from an Elkay kitchen faucet model # LK7124?
Leaky Elkay single handle kitchen faucet - DoItYourself.com ...
www.doityourself.com/.../292646-leaky-elkay-single-handle-kitchen-fau...
Can I replace the cartridge (A54236R) from our single handle Elkay (LK-6360) kitchen faucet without removing it from the sink top? If so where is the secret inhex ...
1/14/2016 11:55:09 PM • Elkay Plumbing • Answered on Jan 14, 2016
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-Arc® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
1/14/2016 11:48:22 PM • Elkay Plumbing • Answered on Jan 14, 2016
How do i replace the flex hose do you have a breakdown
home depot sells universal replacements
5/17/2015 4:41:18 AM • Elkay Plumbing • Answered on May 17, 2015
Draining slowly
try by taking of the trap under sink, and clearing it out ! its the U shaped pipe under sink drain. this is where most of the sinks plug up. unless you have a plugged up drain pipe. do the drain trap first. if this does not solve all of problem, put some good drain cleaner down sink drain. good-day ! and have a merry christmas.
12/24/2011 1:24:31 AM • Elkay Plumbing • Answered on Dec 24, 2011
Restricted flow old kitchen faucet
While not always the case, low flow is usually caused by a plugged aerator. The aerator is the device that softens the water flow as it comes out of the faucet. Unscrew it, remove it, and clean any debris out of it.
Before you put it back, turn the faucet on briefly to flush any other debris out and to see if the water pressure is better. If not, there could be a cartridge (if equipped) issue of some piping problem.
4/23/2011 2:37:48 PM • Elkay Plumbing • Answered on Apr 23, 2011
2answers
How can i get the
Rock it from side to side and pull very hard. Make sure you have the set screw completely removed. After years of use soap gets down inside the handle and around the shaft and can make them very difficult to remove. It will come off if you pull hard enough. You may even have to pry on each side a little to get it off.
3/12/2011 3:51:21 PM • Elkay Plumbing • Answered on Mar 12, 2011
30 year old Elkay bathroom one handle faucet is
If it does have a cartridge, replacing it would only help it stop dripping out the faucet or from around the handle. A leak underneath is most likely to be a failure of the seal from the supply pipe to the faucet, from corrosion and/or hardening of the rubber seal that is part of the supply pipe connection. Shut off the supply. (Hopefully you have a shutoff valve under the sink.) And remove the supply pipe/tube/hose. This is very hard to do without a basin wrench. (All hardware stores have them, and they are pretty cheap.) Take the supply pipe to the hardware or home improvement store to select a replacement. Other than the material and construction of the pipe itself, and the length, there are only a couple of different fitting configurations.
5/8/2010 3:50:04 PM • Elkay Plumbing • Answered on May 08, 2010
How do you remove the cartridge from a LK2454
Call Elkay and they will give you instructions. Thanks anyway.
1/5/2010 3:00:10 PM • Elkay Plumbing • Answered on Jan 05, 2010
Very little water comes out when the faucet is
CHECK THE ANGLE STOP VALVE UNDER THE SINK TO SEE IF IT'S FULLY OPEN. CHECK THE AERATER SCREEN TO SEE IF IT'S PLUGGED UP.
12/13/2009 6:47:43 PM • Elkay Plumbing • Answered on Dec 13, 2009
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
2answers
Acrylic sheet
Hello. You can heat it up with a torch along the bend line and bend it. Be careful as it get HOT. Joe
10/19/2023 9:44:08 AM • Plumbing • Answered on Oct 19, 2023
My Mirolin bath drain stopper had a spring, which went down the drain when I removed the stopper to clean. Now I'm not sure how the new spring I bought goes back on.
This seems like a system which is proprietary to them, so best to ask their Support staff https://mirolin.com/contact-us/ You could have retrieved the old spring with a flexible magnetic reach tool. https://www.google.ca/search?q=magnetic+pickup+tool https://www.google.com/search?q=Mirolin+bath+drain+stopper ..
10/10/2023 11:30:47 PM • Plumbing • Answered on Oct 10, 2023
Kitchen sink hose broken button nozzle
9/14/2023 5:02:50 AM • Plumbing • Answered on Sep 14, 2023
How do i fix getting water to come out of the faucet ?
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
9/12/2023 6:09:20 AM • Plumbing • Answered on Sep 12, 2023
Elkay LK58 Drain Logo
1 questions posted
Top Elkay Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Elkay Plumbing
  • Elkay Plumbing
Most Popular Question
drains technical question
  • Plumbing
