20 Most Recent
Black & Decker Cordless Handi Saw Questions & Answers
Blackanddecker typye 2 recip-saw handi
There is a small ball inside the chuck that sometimes gets stuck on these quick release chucks. Check and see if it is still in there and if it is see if it is stuck. If it is just put a drop of oil on it and keep working it. It will loosen up and you will be back in operation.
BLACK AND DECKER HANDI SAW ISNT WORKING
there are several trouble shooting you can perform:
1. Check the plug particularly teh wire attached on it.almost all of the wires of a power tools got damage on the wires itself due to a continous moving when working.
2. Somtimes there is a built-in fuse or breaker.
3. Check the Switch.sometimes the spring materials of a switch is malfuncioning and it couldn't connect the conductor to run a power.
4. Check your carbon Brush.You must replace it if it is already below 1/4 inch long.
5.Can you feel a little vibration when you switch the unit?if that so,check the bearing because it is surely the bearing has damaged because the armature and core of the motor is already touching each other thats why it will not rotate anymore..
New product registry
Black and Decker's registration website should be able to help you:
http://www.blackanddecker.com/membercenter/
Adapted / charger
OK here is the lowdown the part number you need is 90500144 list for 6.86 and there is a Dewalt service center in Latham N>Y> Ph#518-785-1867 Let me know if you need any more help and if I have helped you would you please rate this solution accordingly. Thank you
HOW TO INSTALL BLADES
OK just looked at manual for the CHS6000 handisaw and there is a lever on the front that you need to press down on fully and insert the blade from the front and then release lever and it should lock. This tool from what I saw can take the T shank blades or standard ones. If you still have trouble I would go to Dewaltservicenet.com and in the middle of the page towards the bottom you can type in your model number and either read the manual online or print out a copy. This manual is 34 pages long. Let me know if you still have problems.
Register new product
Go to Black and Decker again and on the right hand side of the header is a link to MyBlackandDecker.com for registering your new tool. If this doesn't work let me know and I will go a different route.
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
