20 Most Recent
Conair Large Digital Display Memory Tracking Precision Electronic Scale Questions & Answers
This is a new scale. Every time you get on it a
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
How do you use a
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
How to adjust the power setting adjustment screw on a conair model hc200b hair clippers
The power setting adjustment screw on the Conair Model HC200B hair clippers is typically located on the side of the clipper near the on/off switch. To adjust the power setting, you will need to locate the screw and use a small screwdriver to turn it.
Here are the general steps to adjust the power setting on your Conair Model HC200B hair clippers:
- Locate the power setting adjustment screw on the side of the clipper near the on/off switch.
- Use a small screwdriver to turn the screw clockwise to increase the power setting or counterclockwise to decrease the power setting.
- Turn on the clippers and test the power setting by cutting a small section of hair.
- If the power setting is not to your liking, adjust it again with the screwdriver until you achieve the desired power setting.
It's worth noting that the power setting is usually a small screw and turning it too much can damage the internal machinery of the clipper, so it's best to make small adjustments at a time. And ensure the clipper is unplugged before making any adjustments.
