20 Most Recent Tanita BF 350 Pro Body Composition Analyzer Questions & Answers
0answers
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.1. Press&Hold Zero button, then Press&Hold On/Off.2. Release.3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.4. Press Set button to select mode.Hope this helps!
11/19/2013 5:33:42 AM • Tanita BF 350... • Answered on Nov 19, 2013
Does having water effect the
Yes. These systems work by what could be broken down as, "Bio-electrical Impedance Monitoring".
Meaning, they measure the amount of resistance in your body to determine the "volume %" of non-resistive materials (fat and water). Since bones and muscle are very dense in comparison, the scale can calculate the total weight of a person, then determine their "expected BF%). Fat is about 80-90% water depending on your genetic makeup, and it would only make sense that if you where full of fluids (either by ingesting large amounts or by fluid build up under the skin) that your BF% would read higher. My professional suggestion? Use it only after waking and before any morning drink or food.
(REMEMBER...THESE THINGS WILL NEVER BE EXACT!!!) Hydrostatic weighing in the only way to be 99%+ on your BFC (body fat composition)
GOOD LUCK AND PLEASE RATE THIS POST!!
P.S. one way to test this method is to hold something heavy in your hands and watch it consider that weight Lean Muscle Tissue. Then stick your hands in a sink full of still water (moving water posses a small electrical charge that could give a false reading) and watch your BF% increase.
5/9/2011 2:13:30 PM • Tanita BF 350... • Answered on May 09, 2011
0answers
My Tanita KD-300 is showing err6 - what should does it mean?
It seems that the error code "Err6" on a Tanita KD-300 scale indicates that there is a problem with the measurement sensors or the internal circuitry of the scale. This could occur due to a number of reasons, such as a buildup of dirt or moisture on the sensor, a loose connection, or an issue with the battery or power supply. One potential solution is to try cleaning the sensor and making sure it is properly connected. If the issue persists, you may need to contact customer support or consider having the scale repaired. It is worth noting that the Tanita KD-300 model is an older model, and some of the solutions mentioned in the search results may not be applicable to your specific issue. It is recommended to consult the user manual or contact customer support for more information on troubleshooting the issue.
7/29/2023 5:31:53 AM • Tanita Health &... • Answered on Jul 29, 2023
Tanita BC-420SMA Portable Body Composition Analyser. It converted from Kilograms to Pounds. I want to change back To use Kilograms please.
Question edited for a lot more clarity. Here is the manual
Tanita BC-420MA Instruction Manual - ManualsLib
ManualsLib https://www.manualslib.com > ... > Scales > BC-420MA Summary of Contents for Tanita BC-420MA. Page 1 BODY COMPOSITION ANALYZER BC-420MA Instruction manual REMOTE DISPLAY VERSION COLUMN MOUNTED VERSION Please read ... More https://www.google.com/search?q=tanita+420+change+pounds+to+kg& ..
7/26/2023 3:05:56 PM • Tanita Health &... • Answered on Jul 26, 2023
How do i calibrate a tanita 1584 baby scale, i need the procedure Please.
google tanita 1584 baby scale instructions for manual
7/20/2023 4:28:45 PM • Tanita Health &... • Answered on Jul 20, 2023
How to zero Tanita scales
BF-679W/BF-680W - Tanita
Tanita https://www.tanita.com > .downloads > download PDF This Body Fat. Monitor/Scale passes a low-level electrical signal through the body, which may interfere with the operation of a pacemaker. • The Tanita Body Fat ...
3/18/2023 4:06:50 PM • Tanita Health &... • Answered on Mar 18, 2023
I have a Tanita Model UM-061 that has been reliable for years. Now suddenly it is not giving me readings. I tried replacing the batteries and that didn't help. What should I do next?
Leave batteries out overnight to reset. Try another set of fresh unopened batteries. Try and claim on the warranty or ask if Tanita repair https://www.google.com/search?q=Tanita+Model+UM-061 ..
2/3/2023 4:26:49 AM • Tanita Health &... • Answered on Feb 03, 2023
3answers
My Tanita BC-542 when turned on shows88888
Check out this options.:-------- "Error" appears while measuring. Please stand on the platform keeping movement to a minimum. The unit cannot accurately measure your weight if it detects movement. The Body Fat Percentage is more than 75%, readings cannot be obtained from the unit.
Your personal data has not been programmed. Try re-programming. Make sure socks or stockings are removed, and the soles of your feet are clean and properly aligned with the guides on the measuring platform.Otherwise it shows error. ------------------------------ 1. Select Personal Key and Step On Press your pre-programmed Personal key. (Release the key within 3 seconds or the display will show "Error".) The unit will beep and the display will show the programed date. The unit will beep again and the display will show "0.0"/ "88888". Now step onto the platform. If you step onto the platform before "0.0" / "88888"appears the display will show "Error" and Note: you will not obtain a reading. Furthermore, if you do not step onto the measuring platform within about 60 seconds after "0.0"/ "88888" appears, the power is shut-off automatically. ---------------------------- If any of the above mentioned options are incorrect then monitor will display error.This should help.Thanks.Helpmech. ------------
12/30/2021 7:18:22 AM • Tanita Health &... • Answered on Dec 30, 2021
2answers
The display on my Tanita kitchen weighing scale is not bright and I'm not able to read
A possibly silly suggestion but have you tried a new battery?
11/20/2021 8:14:46 AM • Tanita Health &... • Answered on Nov 20, 2021
My Tanita BC-418MA does not work
call the manufacturer first not many people have this machine so we know nothing about them
9/16/2021 1:58:56 PM • Tanita Health &... • Answered on Sep 16, 2021
My Tanita 420 is showing error 40 after trying to complete the body composition anyalysis. any ideas what the issue is?
This is caused by impedances measurements error. please make sure the feets are not dry. Try to spray little water on the platform before the measurement. If error still there you need to do impedance calibration.
7/3/2021 10:00:47 PM • Tanita Health &... • Answered on Jul 03, 2021
I have a Tanita Chinese Scale 570913. I don’t know how to use it and can’t read Chinese. It has five buttons the front side. When is it off button the others says 1 2 3 4. How can l set it? I weigh 84 lbs. It says l weigh 402 kg.
That is 886.258 pounds!! It is broken, throw it away. Or remove the batteries for 5 minutes. For your Chinese buttons, you can use a smartphone with the Google Translate app and use the Camera function to translate what the camera is seeing. It is very clever. Or contact the USA department of Tanita and ask for a manual in English.
Tanita: digital scales for body fat & weight, bathroom, kitchen ...
https://www.tanita.com > ...
For the last 40 years Tanita's has manufactured leading edge weight measurement scales and innovative products that enable consumers to monitor their own ...
5/7/2021 5:08:24 PM • Tanita Health &... • Answered on May 07, 2021
Tanita BF 350 Pro Body Composition Analyzer Logo
8 questions posted
Top Tanita Health & Beauty Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Tanita Health & Beauty
Most Popular Question
having water effect
  • Health & Beauty
