20 Most Recent
Scotts Company Scott'S& Lawn Pro Spreader 3 Pack Questions & Answers
As the cyclone brand spreader is
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Not getting gas
Check the tank and line for more contaminates in line. Had the same problem with my tractor. Ended up taking carb apart and cleaning thoroughly. Blowing out gas line and cleaning the tank out with fresh gas before it would run good again. Try to find out where the water is coming from. Mine was a broken gas cap
Scott speedy green 1000 spreader
The spring at
The spring on the Speedy Green 1000 is more of a plastic bow piece. The accordion shaped piece should run through the "bridge" that is riveted to the hopper and then the bow piece fits into it. It is possible that the plastic bow may have worn out and may need to be replaced. You should give Scotts a call @ 1-800-543-8873 and see if we have a replacement available for you.
