20 Most Recent Mtd 19 In. 173 CC OHV 3-In-1 Questions & Answers
2answers
Motor runs what seems like slow and when you pull handle to start it rips it out of my hand
Make sure that the oil level is not too high. If the blade hit something, it will change the engine timing,which will cause the handle to pull like that. To check to see if the shaft is bent, UNPLUG the spark plug wire!!! Turn the mower on it's side (KEEP the carb side up!)Pull the rope and have a helper watch the shaft. If it's bent, buy a new engine, It will cast about $120-$180 to rebuild the old engine.
6/29/2021 10:09:29 PM • Mtd 19 In. 173... • Answered on Jun 29, 2021
Hit rock, will run a little only
you may have broken the shear key on the flywheel
3/6/2018 3:12:38 PM • Mtd 19 In. 173... • Answered on Mar 06, 2018
How much oil to fill a MTD Gold push 3in1 173cc mower
should be a a dip stick on the end of the filler cap with a gauge
1/31/2018 3:34:36 PM • Mtd 19 In. 173... • Answered on Jan 31, 2018
Idle too low
if you have a idle screw on the carb adjust it
1/21/2018 9:03:21 PM • Mtd 19 In. 173... • Answered on Jan 21, 2018
Hard pull start toro
check the shear key on the flyw3heel
1/21/2018 9:01:25 PM • Mtd 19 In. 173... • Answered on Jan 21, 2018
Mtd 173cc motor only will start with full choke,
clean the carburator
1/21/2018 8:59:00 PM • Mtd 19 In. 173... • Answered on Jan 21, 2018
The motor wont stay running if I spray a little
give the carb. a good cleaning
1/20/2018 4:17:12 PM • Mtd 19 In. 173... • Answered on Jan 20, 2018
Lawn mower wont start after oil change
i can only check for spark if you have spark then go to the carb. check for fuel flow if you have flow clean your carb. one of these is bad.
9/19/2017 1:14:36 PM • Mtd 19 In. 173... • Answered on Sep 19, 2017
2answers
How to restring cub cadet 173cc push mower
take off the hood remove any old string, now wind up the spring and hold it tight put the new string through the hole in the hood and into the hole in the crank wheel pull it through 6 or 8 in. slowly let the spring unwind now tie a knot in the rope and you're done
7/21/2015 1:31:33 AM • Mtd 19 In. 173... • Answered on Jul 21, 2015
The pull cord on my
Yeah I got the same problem. My pull cord broke in the first season. On my own once the plastic cover is removed, 4 phillips screws, the cord housing is secured by 3 10mm nuts. Remove them and lift out the housing. On my own unit the spring had also slipped out of the mount on the shaft securing the assembly (another 10mm socket nut will loosen that). I used a Briggs and Stratton cord from another (truly dead) mower and have had no problems since then. I am not sure why folks are giving you spark plug settings when you are asking about the cord. :)
7/21/2015 1:28:01 AM • Mtd 19 In. 173... • Answered on Jul 21, 2015
WHAT IS THE SPARK PLUG GAP 173 O/V CUB CADET\
.028"-.030"
3/11/2015 12:15:28 AM • Mtd 19 In. 173... • Answered on Mar 11, 2015
How to clean the carberator?
Contact MTD if your manual doesn't cover this, or buy a shop manual, or go to the engine maker's website and look it up.
12/22/2014 8:24:59 AM • Mtd 19 In. 173... • Answered on Dec 22, 2014
Spark gap mtd 173cc mower
Contact MTD if your manual doesn't cover this, or buy a shop manual.
12/22/2014 7:59:00 AM • Mtd 19 In. 173... • Answered on Dec 22, 2014
Why does Mtd 19 In. 173 CC OHV 3-In-1 use a lot of gas
If the unit runs too rich, then replace the carb.
12/22/2014 7:42:21 AM • Mtd 19 In. 173... • Answered on Dec 22, 2014
Engine does not start when warm
here is a problem... No service center to fix this box store lawn mower... If it is brand new I would take it back and get a new one because I would be willing to guess you have either a valve adjustment issue or a bad ignition coil which shouldn't be an issue with a brand new mower.
11/16/2013 8:53:05 PM • Mtd 19 In. 173... • Answered on Nov 16, 2013
0answers
Start rop doesnt retract
sounds like the return spring broke. gotta take it apart and fix
8/16/2013 10:27:43 PM • Mtd 19 In. 173... • Answered on Aug 16, 2013
Mtd 19 In. 173 CC OHV 3-In-1 Logo
42 questions posted
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
  • Garden
