20 Most Recent
Hayward H Series Pool & Spa Heater Electronic Dual Ignition 250,000 Btu Natural Gas H250ed2 Questions & Answers
How do I turn on the heat and the spa in the pool?
You must first make sure the filter pump is on and running (primed). If you have a pool spa combo, you will need to turn on the heater by making the desired temperature higher than the current temperature. This is a call for heat. You must then move the suction and return valves to **** and return to the spa. This is accomplished either by moving the valves manually or by putting it into spa mode if you have a control system. You didn't say whether or not you have a manual or automatic system.
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
I have a hayward h series lp gas heater. 14 months
Check power into and out of the transformer...power issues can cook a transformer quickly causing your issue. If low volt side of transformer is ok you will need to check the control board.
Even though the heater is technically out of warranty you may want to have a tech look at it and see if they can still get any parts needed covered.
To find a Hayward authorized tech in your area, enter your zip code and then select repair as the purpose of your search on
this web page.
Hayward h250ed2 power to unit 240 v . power from
That board is sensitive to power fluctuations and at one point it was recalled. The unit has not been in production for a couple of years now so it is unlikely you'll get warranty consideration from Hayward since if you purchased it 'recently' it should have been on clearance. Your best bet would be to contact Hayward directly and see if they'll send out a warranty provider to get a diagnosis...if you want to proceed contact them at:
http://www.haywardnet.com/forms/contactForm.cfm
I have a hayward H250
Check the connections to the transformer. Inside the front top cover Makesure power is off when doing this
HF code on hayward 200fdn pool heater?replaced gas valve still have same code.What now?
HF
Flame present with gas valve "OFF" error
If flame is sensed with the gas valve off the control will go into lockout. The blower will run until error condition is corrected. When corrected, control will run blower for 5 s then automatically restart after 2 minutes.
the error might be caused by a faulty flame sensor. i have heard of this happening the other way (carbon blocks sensor causing no ignite)
New XtremepowerUS 2HP In-Ground Swimming Pool Pump Variable Speed 2 Inlet 230V High Flo w/ Slip-On Fitting, i turned it on after 2 mins switch from high to low then shut off and get very hot.
All electric motors run hot and pool pumps are no different. But how hot is too hot for a pool pump? The first test is simply whether you can touch the motor or not. Under normal operating conditions, the motor end of the pump is hot enough that you can barely touch it - but not searing hot.Best to you.https://www.google.com/search?q=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&newwindow=1&sxsrf=AB5stBhpriuNhnfXLYYTg7tuS-LWwW262g%3A1690815381903&source=hp&ei=lcvHZKH_NOHi9AOquJjADw&iflsig=AD69kcEAAAAAZMfZpVdAAi94QXZiwKfN3nArsWv-Gm1z&ved=0ahUKEwjhnd6RmrmAAxVhMX0KHSocBvgQ4dUDCAo&uact=5&oq=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&gs_lp=Egdnd3Mtd2l6IkpYdHJlbWVwb3dlclVTIDJIUCBJbi1Hcm91bmQgU3dpbW1pbmcgUG9vbCBQdW1wIFZhcmlhYmxlIFNwZWVkIHJ1bm5pbmcgdGVtcEgAUABYAHAAeACQAQCYAQCgAQCqAQC4AQPIAQD4AQL4AQE&sclient=gws-wiz#kpvalbx=_sMvHZMuPJPez0PEP3M2LgAY_44
