20 Most Recent
Sta Rite Sta - Rite 1hp Dura - Glas Inground Pool Pump, P2ra5el Questions & Answers
Pool pump turns on, starts clicking then turns off
It appears that the motor is overheating, and then it turns off. There is a thermal overload switch that will turn off the heater, and when it cools back down, the motor will turn back on.
A few things to check:
- Debris in the impeller
- If so, remove it, this is causing the motor to overwork
- Was motor / impeller recently changed?
- if motor was downsized from the one prior, it is overworking, because the impeller is still sized larger.
- if impeller was upsized with an undersized motor, the motor is overworking
- Is the motor louder than normal?
- The bearings are probably failing and the creating the motor to labor.
Good luck
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glasPrime the pump after any repairJay the pool pump reapair guy in longwood Florida 32750
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
I am not sure where
None of the above. You hook your two line leads (the two hot 115 lines) to L1 and L2 and you hook up the ground to the green screw. Do NOT connect the neutral to the motor.
I need the wiring diagram
2 YELLOW GO ON 1 POST ON CAPACITOR , THE ONE RED GOES TO THE ONE SIDE OF THE POINTS THE RED/WHIT GOES TO THE POINTS AND TO THE OPEN LUG ON THE CAPACITOR .. SORRY ABOUT THE PICTURE , THE OTHER ONE WOULD NOT LOAD .. JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA .
When I turn it on
Check to see if you can turn by hand, Open housing and do this. Turn on and see if you can spin it and make it start(CAREFUL) If it won't turn ether when off or while it has power going to it, UH-OH! it's time for a new motor. If it will turn and starts when you spin it, it is probably just a start capacitor. Good luck.
I have a sta rite
Hello. your pump motor is worn out. Replace the motor and you will be fine once again. J.
I have a sta rite 1 hp 115/230 motor i cant find
I assume you mean the white wire under the rear motor cover? If so Sta-Rite puts a wiring diagram inside this back cover. Hopefully it is still intact for you. Depending on your model and if it is wired for 115vac or 220vac will make a difference. I would suggest you go to the link I attached and look up your manual. The manual will have the wiring diagram for you.
http://www.starite.com/I hope this helps you out. Please rate my response. thanks
Pump froz and dont start
Is it still frozen?? If so thaw it out first.
If defrosted, will need to strip motor to see if you can hand turn it / free it up.
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
