20 Most Recent
Hayward Easy Clear 40 Sq Ft Cartridge Pool Filter with Pump Questions & Answers
Can't get my hayward filter lid off. It turns a
Sounds like it is stripped. Hope it is the cap and not the part the filter is in. If you are very careful you may get the top off by taking 2 items you can pry with. Either screwdrivers or something similar. Have another person help if there is room. Place one of the pry items under the edge of the cap and put a little upward pressure on it. Have another person do the same thing on the opposite side. Now, carefully start to work the top off. Allow yourself time and patience. It will probably turn with difficulty but keep going. I assume it is plastic and maybe when you take the top off you will cut some new threads. They may allow you to use the same top or not, good luck...Lee
Filter grid alignment
First, I don't understand why I could not submit my question when the filter model I have was not listed in the drop-down of models. As I wrote in my question, I had to choose the wrong filter, JUST to get the question submitted. NOTE: This instruction is for Hayward DE filters. Mine is a DE 6000, but I believe the instructions apply to all sizes.
I did solve my question by:
- Place the grid manifold upside down on a flat surface. (Holes up, remove the air escape tube first.)
- Start with the SMALL filter grid(1 of 8) and insert it in the location hole to the left of the stand pipe inlet. (The LARGE hole in the manifold.)
- Continue inserting the remaining 7 filter grids counterclockwise into the location holes, with the tight curl of the grid going toward the center.
- The base plate (circular swirl piece) is now worked onto the filter grids, BEING SURE THE "CUT-OUT" FOR THE STANDPIPE ALIGNS WITH LARGE MANIFOLD HOLE, where the standpipe will be.
- I found working from the center outward, and giggling the plate as I progressed, the filter grid ends worked their way into place. You'll know it's in place when the plate feels solid and is parallel with the manifold. The filter ends will be in the correct notches and the grids will be symmetrical.
- Drop the stainless center rod (with washer and nut in place) through the base plate and into the hole in the center of the manifold.
- Holding the assembly together, by pressing the base plate and manifold together (with one finger on the rod), turn filter grid assembly over.
- Place washer, and tighten nut, on top of rod. Replace air escape tube and tighten clamp.
- Lightly lube the standpipe with Vaseline and place the filter grid assembly into the bottom filter housing.
- Lightly coat large "O" ring with Vaseline and place onto top lip of bottom filter housing.
- Place filter housing top on top of the filter housing bottom, being sure to create an equal size gap between the 2 pieces.
- Place the clamp ring around the seam and tighten both screws until the springs are completely compressed. (There will be a slight gap between the clamp ring halves.)
- Fire up the pump, add fresh DE through the skimmer return line to the filter, and enjoy your pool.
HF code on hayward 200fdn pool heater?replaced gas valve still have same code.What now?
HF
Flame present with gas valve "OFF" error
If flame is sensed with the gas valve off the control will go into lockout. The blower will run until error condition is corrected. When corrected, control will run blower for 5 s then automatically restart after 2 minutes.
the error might be caused by a faulty flame sensor. i have heard of this happening the other way (carbon blocks sensor causing no ignite)
New XtremepowerUS 2HP In-Ground Swimming Pool Pump Variable Speed 2 Inlet 230V High Flo w/ Slip-On Fitting, i turned it on after 2 mins switch from high to low then shut off and get very hot.
All electric motors run hot and pool pumps are no different. But how hot is too hot for a pool pump? The first test is simply whether you can touch the motor or not. Under normal operating conditions, the motor end of the pump is hot enough that you can barely touch it - but not searing hot.Best to you.https://www.google.com/search?q=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&newwindow=1&sxsrf=AB5stBhpriuNhnfXLYYTg7tuS-LWwW262g%3A1690815381903&source=hp&ei=lcvHZKH_NOHi9AOquJjADw&iflsig=AD69kcEAAAAAZMfZpVdAAi94QXZiwKfN3nArsWv-Gm1z&ved=0ahUKEwjhnd6RmrmAAxVhMX0KHSocBvgQ4dUDCAo&uact=5&oq=XtremepowerUS+2HP+In-Ground+Swimming+Pool+Pump+Variable+Speed+running+temp&gs_lp=Egdnd3Mtd2l6IkpYdHJlbWVwb3dlclVTIDJIUCBJbi1Hcm91bmQgU3dpbW1pbmcgUG9vbCBQdW1wIFZhcmlhYmxlIFNwZWVkIHJ1bm5pbmcgdGVtcEgAUABYAHAAeACQAQCYAQCgAQCqAQC4AQPIAQD4AQL4AQE&sclient=gws-wiz#kpvalbx=_sMvHZMuPJPez0PEP3M2LgAY_44
How can I test if my Hayward gas heater water pressure is working??
Testing the water pressure of your Hayward gas heater is a relatively simple process. Follow these steps to check if your water pressure is working properly:
- Turn off the Gas Heater: Before performing any tests, make sure the gas heater is turned off to avoid any potential accidents or injuries.
- Check the Pressure Gauge: Locate the pressure gauge on your Hayward gas heater. It is usually located on the front panel of the unit or near the plumbing connections.
- Observe the Pressure Reading: The pressure gauge will display the current water pressure. It is typically measured in pounds per square inch (psi). The optimal water pressure for most pool heaters is usually between 15 psi to 25 psi, but it's essential to check your heater's manual for the specific recommended pressure range.
- Turn on the Pool Pump: Ensure that the pool pump is running, as it is responsible for circulating the water through the heater. The water pressure will be at its most accurate when the pool pump is operating normally.
- Monitor the Pressure: While the pool pump is running, observe the pressure gauge to see if the water pressure falls within the recommended range. If the pressure is below the minimum recommended level, it may indicate a circulation issue or a problem with the pool pump.
- Check for Leaks: While testing the water pressure, inspect the heater and the surrounding plumbing connections for any signs of leaks. Leaks can lead to reduced water pressure and affect the heater's performance.
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
AO error code on 250k btu hayward pool heater
Dear ,
Please try the below solutions,
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
