20 Most Recent
Panasonic Shiatsu Massage Lounger with Electric Reclining Ep790k Questions & Answers
THE MODEL IS EP578.ROLLERS DONT
I found with my Panasonic EP578 that, if the lower photo sensor limit switch gets too dusty, the massage mechanism will travel downwards past the normal range of motion and the electronics will time out because the unit did not get a down limit sensor signal & reverse direction and proceed back to the upper limit switch in time. With the device unplugged, I simply removed the grommet screws and opened the fabric backing. Then I removed the units cover and Then blew out dusty photo sensors with compressed air. Then I swapped the red and green, 2-pin mag clutch coil connector plugs so that when I switched the unit on again I could make the unit travel back up to about, the scapular position. The reason that this is possible is that when you first start a normally working machine, the first thing that happens after the motor turns on, is that the motor clutch for the mechanism that provides the neck and vertebral massage balls, also energizes. I figured that I could get the voltage at that connector to energize the rolling clutch to get the unit back up again (as you can't move it by hand). Then I turned the unit off (while stile in cycle) and the swapped the mag-clutch coil connectors back to their original position. Re-starting the machine causes the moving massage mechanism to go through it's Power On Routine which realigns everything to it's 'Home' position and ready to run a fully functioning cycle. Remember to unplug the machine when working on it and keep all fingers, necktie, hair, jewelry from moving mechanism when it's moving to avoid damage to the machine and bodily harm to yourself!
P S here's a link to a service manual .pdf download for the Panasonic EP578:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj_zpzD_NvQAhVpqFQKHb6EBbgQFggeMAA&url=http%3A%2F%2Fblog.lincomatic.com%2Fwp-content%2Fuploads%2F2013%2F01%2FEP578.pdf&usg=AFQjCNESCMv3PGtxbXCJfn-RHnEBwiQoIQ&sig2=2t3ZqNxLVT8Y4RJ6nKolmA
12/5/2016 2:12:05 AM •
Panasonic...
Answered
on Dec 05, 2016
Where do I repair a KSI Shiatsu Power Massager
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
4/22/2012 10:02:01 AM •
Panasonic...
Answered
on Apr 22, 2012
