20 Most Recent Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Questions & Answers
0answers
Poulan 446 poulan manual
Owners Manuals Put in your model number for the manual you need.
12/12/2017 7:54:36 PM • Poulan/Weed... • Answered on Dec 12, 2017
What is 50:1 gas oil mix
That is the ratio of oil to gasoline needed to run this unit. Always use an"FD" rated oil. Better yet, use the pre-packaged fuels they have "FD" rated oils and 93 -95 non-ethanol fuel.
12/12/2017 7:54:00 PM • Poulan/Weed... • Answered on Dec 12, 2017
Poulan ppb 335 diagram
Just remove the mount nuts and pull the cylinder off.
1/25/2015 8:49:57 AM • Poulan/Weed... • Answered on Jan 25, 2015
Weedeater leaf blower starter spring
What about it?
1/25/2015 8:37:16 AM • Poulan/Weed... • Answered on Jan 25, 2015
Poulan pro 25cc/210mph. weak spark. won't start and fouling plugs
Most likely needs a new flywheel.
1/25/2015 8:32:48 AM • Poulan/Weed... • Answered on Jan 25, 2015
Purge bulb staying collapsed and not filling up
you need to clean the carb system and maybe replace the bulb.
1/25/2015 8:19:31 AM • Poulan/Weed... • Answered on Jan 25, 2015
Robin weedeaters head removal
Their id no head on that engine. Unless you have a 4 stroke some how... You will need to remove the cylinder to access the piston.
1/25/2015 8:16:29 AM • Poulan/Weed... • Answered on Jan 25, 2015
How do you replace trimmer head on poulon wt3100 with new one
you should see the mount screws to remove the head, you may have to open the string case and remove parts in there depending.
1/25/2015 8:09:57 AM • Poulan/Weed... • Answered on Jan 25, 2015
If the oil and gas are not quite mixed correctly will that make the weedeater not run
No it will not. If it is too lean of oil it will seize the engine though.
1/25/2015 8:04:24 AM • Poulan/Weed... • Answered on Jan 25, 2015
Blower vac runs at high speed but wont idle
Low speed circuit on carb is blocked. You can try using fresh fuel with some high quality cleaner added and run it through and see if it clear. Otherwise it means the carb has to be removed for cleaning. Which is especially hard these days with the EPA carb plugs on the mixing needles. These plugs are to minimize tampering by owners. You need to be a licensed shop with the tools to adjust the carbs and then put new tamper plugs on nowadays.. Be safe and good luck!
11/26/2014 9:58:08 PM • Poulan/Weed... • Answered on Nov 26, 2014
No gas in bubble
Either your fuel line broke and fell off in the tank or your carb is plugged up and needs to be cleaned. The fuel line can be checked by first dumping the fuel out and looking into the tank. If you see the fuel lines are both intact *(one is long and one is short but both terminate inside the tank) then you probably need to get the carb off and clean it out. Be careful not to use compressed air on the carb as it is delicate. Use a can of carb cleaner only and look into replacing the fuel inlet screen. They come with carb service kits you can buy online for a few bucks. Be safe and good luck!
11/26/2014 9:49:29 PM • Poulan/Weed... • Answered on Nov 26, 2014
I have a riobi leaf blower. it will not start. i have changed the gas,gas filter, spark plug and rebuilt the carb. it still does not start. i took the muffler off to check the screen. it was full of g
The screen was full of gas? Or was that the intake filter? If the carb is moving this much fuel then I would check for spark. You said you replaced the plug but maybe it is the ignition module that is bad. You dumped the fuel first which is the best thing! Try starting with the intake filter off as well. See if the carb is spitting back out the intake. This is a sign the carb may have a checkvalve stuck open. Which will flood it like crazy and prevent starting as it fouls the spark plug. Also....you can dump all the fuel and just put enough in to make it sputter and see if that works. Then you know you have a carb issue without flooding it. Be safe and good luck!
11/26/2014 9:30:49 PM • Poulan/Weed... • Answered on Nov 26, 2014
Wont start
how old is gas? is it ethanol? do u have spark ?
6/27/2014 12:10:37 AM • Poulan/Weed... • Answered on Jun 27, 2014
My weedeater head sins freely but will not spin when running
possible broken cable or gear
6/25/2014 1:18:30 AM • Poulan/Weed... • Answered on Jun 25, 2014
0answers
2answers
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
7/16/2013 11:18:27 PM • Poulan/Weed... • Answered on Jul 16, 2013
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
7/16/2013 10:50:56 PM • Poulan/Weed... • Answered on Jul 16, 2013
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
180 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
weed eater fb25 won 39 t start
  • Garden
