20 Most Recent Craftsman 20 Hp 42" Deck Lawn Tractor Questions & Answers
2answers
Swisher zero turn mower will start but when pto is
safety switch,probably seat.
5/31/2022 7:18:19 PM • Craftsman 20 Hp... • Answered on May 31, 2022
Countax A318HO lawn tractor without electrical function.
Question moved from Cars and Trucks to one of the Lawn Tractor categories. That has all the indications of a battery that has reduced voltage and no cold cranking amps. There is just enough power to light the LEDS and make the relay click. Remove the battery and charge it up. Clean the terminals and connectors with a wire brush and smear them with Vaseline. Reconnect then full charged. Videos https://www.google.com/search?q=countax+a318ho+lawn+tractor+no+power ..
4/5/2022 4:37:06 PM • Craftsman 20 Hp... • Answered on Apr 05, 2022
2answers
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass. Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
5/19/2018 7:01:51 PM • Craftsman 20 Hp... • Answered on May 19, 2018
Video on replacing the grass deflector on a sears riding mower
PartsTreeRepairClinic will help
2/27/2018 2:57:44 PM • Craftsman 20 Hp... • Answered on Feb 27, 2018
20 hp craftsman lawn tractor (2006) stopped
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
1/12/2018 6:04:52 PM • Craftsman 20 Hp... • Answered on Jan 12, 2018
Need a manual for craftsman riding mower that is printable
Go to Sears parts.com and i trhink you can download a manual hopew that helps
12/16/2017 11:48:25 PM • Craftsman 20 Hp... • Answered on Dec 16, 2017
Front left wheel fell off
go to sears parts .com and look up your model and the will give you a parts list and you can check if you have the right part they also have on line and phone help on any of their modfels.
12/6/2017 1:52:06 AM • Craftsman 20 Hp... • Answered on Dec 06, 2017
I have a Craftsman lawn tractor 21.5hp (hydro
If you had included model no. I could have been more help but you probably will have to replace drive plate and or more in transmission. If you go to searspartsdirect.com and in model number type in, hopefully you will get parts breakdown of the transmission showing parts.
10/29/2017 8:11:36 PM • Craftsman 20 Hp... • Answered on Oct 29, 2017
2answers
I have a Craftsman DLT 2000 Garden tractor with a Kohler 20 hp V-twin engine and 48 inch cutting deck. It cranks,Runs fine untill it gets hot. Could be and hour sometimes less. The Key will not crank
sounds like the spindel bearings going bad next time feel spindles for heat ounds like one or more are bad need to be replaced.
10/13/2017 12:28:25 PM • Craftsman 20 Hp... • Answered on Oct 13, 2017
Mower has difficult time moving forward
Is the mower blades engaged if so check spindels if not check the transmisson but check all pulleys first
10/9/2017 3:21:07 PM • Craftsman 20 Hp... • Answered on Oct 09, 2017
Replacing front wheels on Craftsman 917.273013
follow the manual for repairs
6/4/2017 7:33:49 AM • Craftsman 20 Hp... • Answered on Jun 04, 2017
2answers
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
4/3/2017 4:19:32 AM • Craftsman 20 Hp... • Answered on Apr 03, 2017
2answers
Battery won't stay chaRGED NO AMPS SHOWING ON
it could be a fuw things doing this,,,
check that the engine is charging the battery up when its running,,use a volt meeter across the battery it should show 13.5 volts if its charging up ok,,,,
then check that the voltage regulator is not draining the battery when the engine is not running,,,
fully recharge the battery first then check that it holds this charge,, take off the battery lead and leave the mower for a week or so if the battery has gone flat then you need a new battery!! winter time kills off batterys if there not kept on trickel charge,,,
there's a tip,,,,buy a solar charger,,,and hook it to the battery when your not using the mower,,it will keep the battery toped up for free???
1/4/2017 8:10:12 AM • Craftsman 20 Hp... • Answered on Jan 04, 2017
Manual pdf Repair manual Lt 3000 Model 917276813
http://www.searspartsdirect.com/partsdirect/user-manuals/10409/917276813-Craftsman-Parts-TRACTOR-manual?pathRender=fromManualTabPage
5/11/2016 10:05:55 PM • Craftsman 20 Hp... • Answered on May 11, 2016
I need to get spring to engage blades on a craftsman 42in mower back on
see page 24 of owners manual.
11/21/2015 7:06:24 PM • Craftsman 20 Hp... • Answered on Nov 21, 2015
44" v-belt needs to be replaced
Look under footrest for diagram on sticker.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
11/14/2015 12:39:23 AM • Craftsman 20 Hp... • Answered on Nov 14, 2015
Lawnmower tractor turns more to the left then to the rightt
look at the plastic connector where the steering shaft meets the main gear the plastic wears out and the gears jump out of time its a $15 part at sears parts online
11/7/2015 4:50:30 PM • Craftsman 20 Hp... • Answered on Nov 07, 2015
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
551 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
blade engagement lever won 39 t
  • Garden
