20 Most Recent
Electrolux Gas Hedge Trimmer Questions & Answers
My hedge trimmer keeps switching off
It sounds like you may have a loose wire some where that is grounding out. You might want to check all wire connections to make sure that they are tight and also check for any bare spots in the wires were they could be touching metal and grounding its self out.
Trimmer Question
mains, battery or petrol
A hedge trimmer can be powered in 3 ways: mains electricity, rechargeable battery or petrol. They all have their advantages and disadvantages, so decide which is best for you.
Electrical hedge trimmers provide a clean lighter weight option with the convenience of immediate and continual use. However you may be restricted by cord length - not ideal if the hedge is a long way from your power source and having a cord can be obtrusive and dangerous.
Rechargeable hedge trimmers give you the best of both worlds. They're clean to use and have no cord so they can be used anywhere, without the danger of accidentally cutting the cord. They are less powerful than petrol models and you do need to plan ahead though and make sure your batteries have been charged. 5-7 hours of charging will give you just 30 minutes use. A second battery will give you back up but if you're cutting for long periods of time, you may find this timescale too restrictive.
Petrol hedge trimmers can again be used anywhere, there's no cord so they're safer. Just top them up with petrol and away you go, no charging necessary. These models do tend to be harder to use - they're heavier, noisier and smoky.
I need to find a
sheesh , thats a tough one, I'm sure if you take the ccap to a local lawn mower repair ashop they can cross reference one for you
