20 Most Recent
Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI Questions & Answers
Will not start up when
i would check too make sure you have the correct motor oil usualy a lighter grade oil for winter months
1/2/2011 12:46:17 PM •
Northstar...
Answered
on Jan 02, 2011
Rats got into the heating
Any of the companies listed below can help you and are located in your area. These are all trained and certified service centers that specialize in pressure washer repair among other things.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
INNOVATIVE CLEANING SYSTEMS (ICS)
8724 WEST MALBORO ROAD
FARMVILLE, NC 27828 UNITED STATES
(252) 521-4291
CTS CLEANING SYSTEMS,INC
2185 ANGELIA M. STREET
FAYETTEVILLE, NC 28312-8398 UNITED STATES
(910) 483-5349
CSC INDUSTRIAL SALES & SERVICE LLC
600 - D UNION WEST BLVD
MATTHEWS, NC 28104 UNITED STATES
(704) 684-0223
MVP SERVICES, INC.
5813 A. TRIANGLE DRIVE
RALEIGH, NC 27617 UNITED STATES
(919) 788-0267
CLEANING SYSTEMS OF THE TRIAD
5610 RANDLEMAN RD.
RANDLEMAN, NC 27317 UNITED STATES
(336) 676-7283
Oil leak at top of pump
The oil in the pump is probably leaking because a seal is blown and water is getting into the piston housing. Take a look inside at the oil. It should be brown and translucent. If it is gray, white or milky, you have a blown oil seal. This reservoir should only be 1/3 full of non-detergent oil to begin with. Hope this helps
Low water pressure
Water inlet filter lime or dirt , 2 nozzle dirt 3
floss with o-rings valves 1 valve has dirt or broken o-ring between 1 of the valves 4 pressure control valve was not screwed. the nozzle (if it is a dirtkiller) is is broken mostly porcelain.
What is an uploader
I think you mean an UN Loader this is a valve that redirects (bypasses) the pressureized water back into the intake when you release the trigger When it is not working the machine continues to build pressure and will bog down
hope this helps
the ed
