20 Most Recent Delta ShopMaster 8in Grinder with Light GR350 Questions & Answers
Delta bench grinder model 10 bges are the threads l/h or r/h
The right side should have right-hand threads, the left side should have left-hand threads.
7/29/2014 12:11:54 AM • Delta ShopMaster... • Answered on Jul 29, 2014
I have a single speed Delta 8" bench grinder. How
as for slowing it down, no problem. Hook it to a cord with a dimmer switch connected to it. Make sure your running with the same power rating though. As for a dripper, no ideas just yet.
3/10/2011 7:31:47 PM • Delta ShopMaster... • Answered on Mar 10, 2011
To sharpen tools
The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
7/30/2010 12:07:30 AM • Delta ShopMaster... • Answered on Jul 30, 2010
Delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
9/11/2008 6:23:03 PM • Delta ShopMaster... • Answered on Sep 11, 2008
Bench Grinders Featues
A bench grinder is a very simple tool. The units are usually listed as 6-inch or 8-inch wheel models, and the 8-inch units are typically a bit more powerful, and subsequently more expensive. A 6-inch model will usually be powered by a 1/2 HP motor, where the 8-inch will be larger, likely 3/4 HP. Two very useful features to look for are a mounted work light, which will directly illuminate your work, and an adjustable rest, which functions much like the tool rest on a lathe. Strongly consider models which have both features. Many also include a clear, see-through spark guard, which will help keep any sparks from flying toward your face. A word of caution, though: such a guard does not replace safety goggles.
8/27/2008 12:30:53 PM • Delta ShopMaster... • Answered on Aug 27, 2008
My Delta 23-197 variable speed grinder will not run. Only tried it once and it's been put up for a couple of years. Will not start. Light comes on. Has power
It's possible that the variable speed control may be the issue with your Delta 23-197 grinder. However, before attempting to bypass it, there are a few other things you can check. First, make sure that the grinder is properly plugged in and that the power outlet is functioning correctly. Check the power cord and make sure that there are no cuts or breaks in the cord. Next, check the switch and make sure that it is properly engaged. If the switch is faulty, it may need to be replaced. You can also check the brushes on the motor to see if they are worn out or damaged. If the brushes are worn out, they will need to be replaced. If none of these troubleshooting steps resolve the issue, it may be possible to bypass the variable speed control. However, this is not recommended unless you have experience with electrical wiring and understand the risks involved. If you do decide to bypass the variable speed control, you will need to identify the wiring that controls the speed control and connect the wires together to bypass the control. However, keep in mind that this will result in the grinder running at full speed all the time and may shorten the life of the motor. It's always best to have a qualified electrician or technician perform any electrical modifications to your tools.
2/28/2023 5:18:28 AM • Delta Grinders • Answered on Feb 28, 2023
Can my Delta 23-660 "two grinder wheels" be used with only one wheel. One wheel was lost in a move. Can't replace it immediately
I have used a double-ended bench grinder for years with only a single wire brush, without problems.
6/13/2019 4:32:50 AM • Delta Grinders • Answered on Jun 13, 2019
I have a Delta 6 bench grinder model #23-680. How do I hold the shaft from turning as I loosen the nut hold the grinding wheel in place?
Hold (or lock) the grinding wheel on the other side if loose or lock because the locking direction is the same direction and don,t forget to ringing (sound-check -like a tuning fork) the stone if you replace it with a new one The risk is small but safety first
4/19/2017 7:42:00 AM • Delta Grinders • Answered on Apr 19, 2017
I have a Delta Model 23-660 that won't start anymore. For awhile, if I gave the wheel a spin by hand it it would start, but not not at all. I'm assuming brushes? If so, what brushes would it take?
  • there is also an
  • centrifugal circuit inside one- side of the motor electricfield (not in the spare parts to see or order) that could have a problem but first measure the capacitor
  • There are no brushes used its an induction motor. with start capacitor and an centrifugal switch. that was when you give a swing to the grinder the capacitor you needed has an 8 or 10 microfarrad 250 volt AC to start i think but be shure the start centrifugal is in good order and the capacitor together.
  • Delta 23 660 Type 1 Grinder Parts
3/6/2017 7:10:36 PM • Delta Grinders • Answered on Mar 06, 2017
2answers
Have tried everything, can't get
On a bench grinder the wheels turn towards you. This means the grinding wheel on the right side, has a right and nut, and the left side has a left handed nut. If you're trying to remove the left side turn the nut counter-clockwise
2/25/2016 12:23:03 AM • Delta Grinders • Answered on Feb 25, 2016
How to remove wheel on delta 10' grinder
Unplug it first, if you like your skin. Use a wrench on the nut, and hang onto the wheel with one bare hand while you turn the nut in the same direction as the wheel normally spins. If you have a lot of difficulty doing that, jam the wheel with a piece of wood.
7/29/2014 12:15:12 AM • Delta Grinders • Answered on Jul 29, 2014
New shaft for a delta 23-840
You need to check if the cost of the shaft will be too much and whether it makes sense. You have not indicated the reason for changing the shaft, if there is damage e it can be mended in most cases with the help of a machine shop.So check cost with replacement before you attempt.
10/29/2011 3:02:58 AM • Delta Grinders • Answered on Oct 29, 2011
I own a Delta 23
first mark the caps so that when you reassemble they will align properly, Next get a small screwdriver and GENTLY pry the cap apart. One end probably has a rotating switch with wires coming from it so be careful. When reassembling you can use a small piece of wood to tap the end bells back into place.
4/4/2011 1:45:47 PM • Delta Grinders • Answered on Apr 04, 2011
Grinding wheel for Delta
It should take a standard grinding wheel, available at almost any hardware store.
10/13/2009 3:29:04 PM • Delta Grinders • Answered on Oct 13, 2009
Grinder won't turn on
It sounds like the capacitator might be bad or the starter windings. What you can try and BE CAREFUL is turn the switch on and spin the wheel by hand in direction it will be running to see if starts. Again BE CAREFUL
9/28/2009 12:11:28 AM • Delta Grinders • Answered on Sep 28, 2009
I require part #1320210 for a 6
The new part number is 901912. You will have to contact a Dewalt service center to see if they can rustle one up for you. They are no longer available directly from Dewaltservicenet.com but you may get lucky contacting a service center.
9/14/2009 1:14:45 AM • Delta Grinders • Answered on Sep 14, 2009
2answers
Bench grinder is firmly anchored, but still has a
I would take a look at the wheels or wire brush before I went any further. Then I would remove both and just run the grinder to see if still vibrates. But usually one or both of the wheels are out of round.
3/20/2009 4:54:39 PM • Delta Grinders • Answered on Mar 20, 2009
3answers
Price for used Grizzly G1550 metal lathe
depends on condition and what comes with it. generally starts at $500 in good shape and up to 850 if excellent with many extras (chucks, rests, knurling attach, faceplates, etc) Also, check for accuracy...
2/4/2023 8:24:56 AM • Grinders • Answered on Feb 04, 2023
May I eliminate a Circuit Breaker or protector from a Skill Mini Grinder 9310
Yes all the tool places say discontinued. Yes, bypass it, but make sure you don't overwork the grinder. https://www.google.com/search?q=2610904741 ..
10/26/2021 11:13:01 PM • Grinders • Answered on Oct 26, 2021
My Makita DGA505 Angle Grinder with a BL Motor starts then quits. This is the second time it has happened.
Out of warranty ... time for a replacement machine.I would choose a different make. Assuming the batery is not the fault.
9/17/2021 12:07:38 PM • Grinders • Answered on Sep 17, 2021
Delta ShopMaster 8in Grinder with Light GR350 Logo
7 questions posted
Top Delta Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Delta Grinder Expert? Answer questions, earn points and help others
View Most Popular
Delta Grinders
  • Delta Grinders
Most Popular Question
delta bench grinder model 10 bges
  • Grinders
