20 Most Recent
Campbell Hausfeld 3/8" Ratchet Questions & Answers
When trigger is pushed lost of air through the exhaust. never spins ratchet
take some oil and lube the head of the ratchet real good and then take a wrench and put it over the square socket attachement and try working it back and forward and also keep working the position knob .if this frees it up put 5 or 6 drops of oil in the air intake connector and plug yor air line into it and pull yor trigger .remember run it in both directions.hope this helps.
9/14/2016 2:01:39 AM •
Campbell...
Answered
on Sep 14, 2016
Ratchet troubleshooting
Squeeze 4-5 drops of pneumatic tool oil into the air fitting daily. If you use the tool all day, repeat the process half-way through the day. If you don't use the tool very often, just oil it when the tool is used.
9/29/2014 2:05:20 AM •
Campbell...
Answered
on Sep 29, 2014
Earthquake 3/8
Did you put a few drops of oil in the air inlet end? Then connect to the air compressor hose. Make sure you have at least 90 ft lbs of air presssure.
2/18/2013 9:13:37 PM •
Campbell...
Answered
on Feb 18, 2013
Where do you oil the air ratchet
Put a few drops in the end where the air hose connects every time you use it. Put oil in the air inlet end and squeeze the trigger to force the oil through to lubricate the rotor vanes and bearings. Also do this before you store the ratchet in the drawer so that oil sits in the ratchet protecting the internals when not in use keeping the rust away.
2/18/2013 9:02:55 PM •
Campbell...
Answered
on Feb 18, 2013
At what torque should lug nuts be tightened
Instructions
Check the maximum pressure rating of the air tank. The rated
pressure is indicated in pounds per square inch (psi). If there is no
indication of limit on the tank, do not use it.
Drain any accumulated moisture from the compressed air tank
before filling. If the tank has no drain valve, you may skip this step.
Remove the cap from the fill valve. The valve is the same
size and type as used on automobile tires. The location of the valve
differs depending on manufacturer.
Attach the fitting of the air supply hose to the valve stem
of the air tank and depress the fitting firmly. If the air tank has its
own pressure gauge installed, keep a close watch to avoid
over-pressurizing. Wear safety glasses when filling the air tank.
5
Stop filling the air tank periodically and check the tank
pressure using an air pressure gauge if the tank does not have one
installed. As the air pressure in the tank increases, check more
frequently until the maximum amount is reached.
6
Remove the air supply fitting and replace cap.
2/18/2013 8:52:43 PM •
Campbell...
Answered
on Feb 18, 2013
Campbell Hausfeld air gun has air coming from the nose tip and no nails
If air is coming out from the nose tip but the nailer is not firing any nails, it could indicate a problem with the driver blade or piston assembly. Check if the driver blade moves freely and is not damaged. Make sure the piston assembly is properly aligned and lubricated. Also, check the nail magazine to ensure that it is properly loaded and the nails are the correct size for the nailer. If the problem persists, it may be necessary to take the nailer to a professional for repair.
2/14/2023 2:59:32 AM •
Campbell...
Answered
on Feb 14, 2023
Need to know start cap specs for c1071080vmsa campbell air compressor
Kranson 3 Nov 03, 2022
I'm late to the party, BUT...
There's 2 ea of both start and run capacitors in this compressor...
Start: PN- 351052-53, 815-970 MFD, 165VAC
Run: PN- 175863-30, 30MFD, 370VAC
The section ^^ UP THERE ^^ is for asking the OP further information before committing to an answer down here. The question is now marked SOLVED and will show in Search. Thanks
11/3/2022 5:10:21 PM •
Campbell...
Answered
on Nov 03, 2022
Campbell hausfeld wont build pressure
The most probable are
Leak in air lines, bad valves, bad piston rings or o rings., bad check valve on tank, leaking unloader valve. Tou can google your model number and there will be more info.
10/30/2021 3:21:28 PM •
Campbell...
Answered
on Oct 30, 2021
Why does my campbell hausfeld 80 gallon 2 phase air compressor start to bog down at 90 psi
There is many reason for this simptome ,
could be running capacitor ,, Pressure switch dirty or it going bad,, Or ,If you meen lick choking and conteniu going could be also your check valve ,,,
If you can post a video I will help you better ,
I need to hear what it doing ,
9/8/2019 9:33:07 AM •
Campbell...
Answered
on Sep 08, 2019
