20 Most Recent
Pride Victory 4 Wheel Scooter Questions & Answers
Why does it go-stop-go-stop?
The Controller maybe over heating. another thing that could cause this is loose connection to the battery. Throttle may have broken wire and when you hit a bump looses connection. If you let the scooter sit for 10-15 min. before trying again that could have worked better for you. I’m happy to assist further over the phone at
https://www.6ya.com/expert/bill_bcbb89783b08c489
Switch on, Press Wig Wag, Click click No Motor
Hi Peter, as a matter of interest check the brush holders, i seen a hugh number of those scooter lose the carbon part of the brush holder on the motor, they should be sticking out slightly or inwards...
otherwise . the throttle pot or wig wag as it can be called.
does the lever seem loose ?
A controller fault and i can test it for free for you , you only pay for the return postage..
Normally a blue unit..
Regards
Rob
After using the scooter for about 15-20 min. much
Phud Bad brake!!! the brake disc pad is dragging on the motor housing and causing the squealing and battery drain. The motor housing is also getting very warm after that period of time. Replace the brake assembly Hope this helps
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual.
https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
The latch won't stay latched on pride jet 3 ultra
If the latch on your Pride Jet 3 Ultra power wheelchair won't stay latched, there are a few potential causes and solutions you can try:
- Check for obstructions: Inspect the latch mechanism and the surrounding area for any obstructions or debris that may be preventing it from latching properly. Remove any obstacles and ensure that the latch can move freely.
- Adjust the latch position: Sometimes, the latch may need to be adjusted to ensure a proper fit. Check if there are any adjustable components on the latch mechanism and try repositioning them to achieve a secure latch.
- Tighten or replace the latch: If the latch is loose or worn out, it may not hold securely. Check if there are any screws or fasteners that can be tightened to secure the latch. If tightening doesn't solve the issue, you may need to replace the latch with a new one.
- Seek professional assistance: If the latch continues to have issues or you are unsure about making adjustments or replacements yourself, it's best to contact Pride Mobility or a certified technician for further assistance. They will have the expertise to diagnose the problem and provide the appropriate solution.
