20 Most Recent
Black & Decker BR300 3''x18'' Belt Sander Questions & Answers
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
How do you change the belt
The front roller (usually a metal cylinder) is spring loaded. The rear roller (usually a rubber cylinder) is fixed and is driven by a belt from the motor. You need to push the front roller against a fixed object (like a benchtop) pretty hard to compress the spring about 1/2 inch. It should "catch" in the compressed position. Belt will now be loose and easy to reeplace. Then, to "un-catch" it, on most models, just stick a screwdriver behind the front roller bracket and pry it forward. It should pop right back into place. Good luck.
HOW DO I REPLACE A
On the side of the sander there is a black triangle shaped cover with 3 screws holding it in place. Remove the screws and you will see the drive belt and 2 pullies or gears. The belt will be attached to the gears. Remove and replace the belt. Typically the belt is broken so the only thing you will need is to locate a new belt and slip in over the gears with the side with the teeth facing the gears. This keeps the belt from slipping. Reinstall the cover and you are ready to go back to work. The hardest part may be finding a supplier for the belt.
How can i tighten the spring so the sanding belt
Hi Anthonyk,
The view of the b&d br300 I saw was rhat the sanding belt goes automaticly.Maybe you need to check the system or try to telephone local shop where you bought it .
Greatings from holland
Appie
I have a Black and
You might try Dewalt. I have a Black & Decker weed eater that had a broken belt and I had to order it from Dewalt. I was told that they had some kind of merger. Ordered it and it worked just fine.
Need drive belt fpr br300
if you do not find it, you could change one of the pulleys, with one of greater size, of course this will affect the speed, but is an alternative.
I want to replace a
Look between the rollers that the sandpaper belt travel on. You will find a lever which can be released. Once you release it, you can pull the old belt off and slip the new belt on. Place the release lever back the way it was and you are done.
How do you keep the
theres a adjustment screw on the side to adjust so it wont move side to side
