20 Most Recent Samsung Healthy Living Deluxe Wrist Blood Pressure Monitor Questions & Answers
My BW 325S pumps up
The unit may need to be re-calibrated. In which case, you need to return it to the manufacturer. Most will do it for little or no charge, as long as you have your Proof of Purchase.
3/28/2011 5:52:57 PM • Samsung Healthy... • Answered on Mar 28, 2011
I have to reprogram it the batteries went dead.
It should pick up where you left off, how long were you without batteries? There is a small watch battery that should have held the infor for 3 days....
9/6/2010 11:30:32 PM • Samsung Healthy... • Answered on Sep 06, 2010
Can i reset the memory on the digital wrist bp
yes, hold the memory button and the power off, it will clear out the last few numbers for you
9/6/2010 11:08:05 PM • Samsung Healthy... • Answered on Sep 06, 2010
Band of samsung deluxe wrist doesn't tighten,
Dear ramariano: This device is probably TOO BIG for YOUR wrist. Just like regular preassure moniters in my Dr office I have different sizes. Measure your wrist circumfrence and get a compatable machine. Dr Ron Grassi,DC.,MS,Jupiter,Florida.
10/13/2009 12:19:51 PM • Samsung Healthy... • Answered on Oct 13, 2009
I cannot set the time and date.
to set date and time
1. Click on left arrow (mode) the month will blink
2. Click on right arrow to advance to the month
3. Click on center (start/stop) then day will blink,
then continue with right then center until you have date and time entered then click on the left arrow to finish
5/18/2009 3:04:51 AM • Samsung Healthy... • Answered on May 18, 2009
Error display
This link will allow you to troubleshoot questions...I hope this helps.
http://www.samsunghealthyliving.com/support.asp
1/7/2009 8:00:21 AM • Samsung Healthy... • Answered on Jan 07, 2009
How tight should I put
Up to about 160mm for average blood pressure-up to 210mm for elevated Blood pressure. As the pressure lets down it will squeeze several times as it calibrates itself. Hope this helps.
12/29/2008 4:08:56 PM • Samsung Healthy... • Answered on Dec 29, 2008
Samsung Robo Vacuum - bad guidance system
The vacuum cleaner could very well be broken and you will need to buy a new vacuum cleaner. Costco and Amazon sells robot vacuum cleaners.
2/24/2022 2:31:27 AM • Samsung Health &... • Answered on Feb 24, 2022
2answers
SBM-300F spare parts
Samsung Blood Pressure monitor model SBM 400 F needs ...
www.fixya.com/.../t7624392-samsung_blood_pressure_monitor_model
Jan 3, 2011 - Samsung Blood Pressure monitor model SBM 400 F needs new bladder. Are they ... Video; Photos; Link; Replacement Parts. Add. Upload ...
Samsung innotek collar replacement parts Blood Pressure ...
www.fixya.com > ... > Blood Pressure Monitors
Samsung blood pressure monitors innotek collar replacement parts related questions and answers. Ask your ... I have a samsung SBM-300F BP Monitor. It is not ...
Samsung Blood Pressure Monitor Product Support ...
personalcare.manualsonline.com/support/.../blood-pressure-monitor/
Need replacement bulb pump. Samsung ... I am looking for the samsung HD503manual can you. Samsung ... Samsung Blood Pressure Monitor Sam 300f.
Blood Pressure Monitors Parts and Accessories
4/2/2018 10:26:03 AM • Samsung Health &... • Answered on Apr 02, 2018
Wear hearing aids.have a com pilot but cannot hear netflex thru mt samsung smart tv?
My wife has significant hearing problems in both ears. About 4 years ago, we invested in wireless headphones for both of our TV's. Problem solved. Now, she can take her hearing aids out, put on the headphones and everything is fine. Although I have no hearing issues, I too sometimes use them with great improvement - especially in British movies or where there is a lot of background noise. I highly, highly recommend them. We have two pair of Senheisers which we use constantly (mostly her). About $100 for each set. If you have a fairly new TV, hookup is easy, and the best part is that I don't have to turn the volume way up for the headphones. She can crank them up while I listen at a normal volume. DO IT. MAKE THE INVESTMENT. YOU WILL BE SO GLAD YOU DID.
7/27/2017 1:58:33 AM • Samsung Health &... • Answered on Jul 27, 2017
Digital wrist model # SR303S,
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
1/7/2017 12:06:56 AM • Samsung Health &... • Answered on Jan 07, 2017
Where can i buy spare parts in Brisbane
go on line to google --type in the manufacturer and model of what ever it is you want parts for and look for a page that has distributors or service centres for what you want in Brisbane.
5/14/2015 10:37:35 AM • Samsung Health &... • Answered on May 14, 2015
Samsung Healthy Living Deluxe Wrist Blood Pressure Monitor Logo
Popular Tags
15 questions posted
Top Samsung Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Health & Beauty
Most Popular Question
cannot set time date
  • Health & Beauty
