20 Most Recent
Mabis Automatic Digital Blood Pressure Monitor 04-342-000 Questions & Answers
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Looking for directions on how to use Mabis 04-235-001.
this the website for the MABIS companies instruction manuals for their medical items. You can just go to that site and enter your model number and it should take you to the instruction manual to show you how to use your blood pressure monitor. Hope this helps! Good Luck and God Bless!
http://www.mabisdmi.com/downloadsupport/default.aspx
I have MABIS healthcare
Hold the scan button and wait for the arrow on the screen. Keep holding the scan button and push the memory button. You have to do it before it beeps.
We have a Mabis signature palm
Lots of things are retained by a metal ferrule when new but often they eventually fail to do the job properly or are lost or corroded away so they must be replaced by one of the huge variety of hose clips available today and/or one of the many sealers or adhesives also generally available.
In addition to those methods there is available the original - three or four turns of parcel wire and a twist to secure or a variation, using a modern nylon cable tie that is long enough to go around twice before tensioning. The parcel wire method can be very neat and further made more acceptable by covering with adhesive pvc tape.
If you have any doubts about your ability to make do and mend, I suggest you find a general auto repair shop that employs a greybeard...
