20 Most Recent
Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV Questions & Answers
Pride destiny error codes
Pride's website has a service manual for download. It will define the error codes and tell you how to fix it.
Scooter shudders when starting and after stopping
hi, now firstly you need to check all connections fitting all plug connectors, remove one battery lead before proceeding so you don#t accidentally short something ... Now having done that you need to make sure the break is not losing power otherwords coming on, Check the brushes and let me know how you get on ...
Regards
Rob
www.gewizrepairs.co.uk
How can I trouble & fix my scooter
hi sounds like youre circuit has shut down if your have had it in free wheel it will shut down all the lights will work take the key out put it in drive and put the key back if it has a similar circuit as a pride XL it should work...........one more thing if u leave the key turned on for 20 minutes the circuit will shut down all the lights will work take key out wait for a few minutes & put the key back in ..if this does nothing get youre batteries checked with a ..battery load tester .....good luck
I own a Hurricane PMV
hello lou,
it sounds definetly like you need a new motor in any case if the problem where to be fixed by a serviceman they would provide you with a guarantee. How long of a guarantee is another issue and you would have to work that out with them. You could also contact pride directly who would put you in touch with a repair company that would offer some sort of guarantee but due to your unit being so old they would most likely only guarantee the part that they put in as new along with the labor work provided. It might be more economical to look into getting a newer or used model here is the link to contact pride directly
http://www.pridemobility.com/contact.asp if you have any further questions message me back I await your reply Thanks Rick
How do you remove the back wheel of a Pride
Undo the centre wheel nut and remove along with the washer, jack the rear of the scooter off the ground then slide the wheel off the axle. If it will not remove, it will need knocking off from the inside rim. Be careful not to lose the hub key (a small piece of metal that locates in a slot in the wheel and axle) as the scooter will not drive if this is missing. To remove the trye from the rim, undo the 4 bolts that hold the two wheel halves together. When refitting the wheel, be sure to apply some grease to the axle before sliding on the wheel.
Hi, I am trying to
You should check the batteries when loaded, if they drop down below 9VDC, then perhaps the batteries need replacement.
Barring that, you can troubleshoot this problem by testing the power circuit from the batteries to the motor. Attach the negative lead of your tester to the battery, and then start testing for 12 vDC through the circuit.
The click that you hear is probably a relay that passes the heavy current from the battery to the motor. Make sure power is going into the relay and power is going out when you push the button
Hogh - low speed switch is incorrectly wired , but
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Pride hurricane pmv just replaced batteries
Are any of the lights coming on? If so, are any flashing, and if so, how many times or is it constant? Check to make sure the freewheel lever is not bumped which will cause a no-go status. Put in freewheel and place firmly back in drive (located at the rear of the scooter).
Go back in and make sure all of the snap connections are tight. Undo them and redo them, don't rely on a visual inspection. Check the circuit breaker; push it in to reset. If it has tripped, you will feel a click when you push. Check all the fuses.
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual.
https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
